buzzword
Heyo! Thanks for the heads up on the loose sprocket nut. The seal was probably fine, in retrospect - got it torqued up today, and added a bit of blue loctite for posterity.I saw your post in the other thread:
http://www.xs650.com/forum/showpost.php?p=463735&postcount=1822
And, thought of putting a response here. A loose sprocket nut guarantees oil leakage on the left side. Hopefully that's all it is. Otherwise, if the clutch pushrod seal is indeed leaking, consider these:
The bushing behind the seal. The pushrod should show very little, if any, wobble in that bushing.
Let me know if there's any grooving of the pushrod in the seal area. I'll send you another if necessary.
Check for dimpling on the end of the 8mm adjuster screw. That dimpling could cause side deflection of the pushrod.
Hope all's going well for you...
Two things - I think the bushing is indeed borked based on play, and I am pretty sure I messed up the lip seal when I installed the new one, even though I followed every tutorial I read on here - chamfered the edge, etc. I ordered two new seals, and two new bushings - just-in-case insurance. Should be here Friday.
As such, it's leaking from the clutch rod, and the leak is even worse than it was when the sprocket nut was loose. The rod itself seems OK - maybe some slightly less-polished areas are visible on it, but nothing dramatic. Thanks for your kind offer as well, but I think it's OK for now. Here's a pic of the leak.
Things are going OK - daughter is 9 months old now, and she'll be walking any time now. Got laid off a month or so ago along with 25 others, but that's the breaks of startup life. They grew too fast, and it bit all of us in the rear. Oh, well.
