That’s where my short is coming from…Without me reading back through, what makes you think the stator's bad?
Rotors rotate...That’s where my short is coming from…
Make a suggestion? Hearing that thing run would do wonders to encourage you... will put a shit eatin' grin on your face.
Were it me, I'd pull the brake bulb out so it's not a factor... screw the blinkers, screw the charging... I'd ignore everything except getting spark to the plugs. A little vroom vroom and some blue smoke would do wonders for your disposition.
Yes, everything needs sorting. All in good time. Let's work on putting a smile on your face.
Honestly man… No clue. Despite immersing myself in literature this weekend, I’m just barely cracking the surface of understanding the system. What I know is that when the stator is connected I blow fuses. I have no clue where my short is coming from, and it’s stressing me out. I need to find a trouble shooting thread I saw someone vaguely refer to, but I opened up the tech tab, started to read, and decided I didn't have it in me to try and hunt anymore this weekend.Rotors rotate...
Stator's are stationary...
Which are you referring to?
Comment's # 2 and 3...I need to find a trouble shooting thread I saw someone vaguely refer to, but I opened up the tech tab, started to read, and decided I didn't have it in me to try and hunt anymore this weekend.
Went and poked around some today. Got a new headlight, confirming my suspicion that the bulb was causing my problem. More or less confirmed that my fuse-popping short is coming from the charging system.
I still have no blinkers, but I confirmed my relay is not doing any flashing. When I power it, the test light is on constantly (despite the fact that my blinkers never come on at all).
Discovered another new anomaly: the brake light is on all the time. Lights on or off; brakes depressed or not; one of both switches entirely disconnected. AWESOME.
Waiting on filters and a few odds and ends before I attempt to kick the bike over.
Gotta admit to feeling pretty discouraged today. Learning that my PMA bright idea was not so bright; paying the restocking fee on that, leaving me with a broken stator… never ending light issues. This isn’t as much fun today.
Ok… thanks for this link. I failed the slap test. I don’t get any magnetism. I won’t be able to do the rest of the tests until I get kicked over. Hopefully this week I’ll have some more answersComment's # 2 and 3...
2 explains the basics of charging.
3 gets into troubleshooting.
https://www.xs650.com/threads/rewound-alternator-rotor.54276/post-584934
Sir… I am a first-timer who just swapped my entire wiring harness (because the old one had torched itself) and who now has a bike with several known issues, several of which (horn, flasher relay) I found using the method from your link.I offered a solution, (with a link), to sort out problems in a loom and switches.
This should b done on all old bikes to eliminate on going electrical problems.
Fixing one problem and hoping the rest of the loom is good is another problem waiting to happen.
I did however do a bunch more testing with the meter and the fuses, and managed to isolate my short to the regulator. O’Reilly by me had a VR115, so I wired up a 3-pin connector, and… voila! No more short.
I’m not sure what you are saying I’m doing wrong at this point, but I promise I’m not trying to be a whiner or a tell-me-what-to-do. I am using a meter (also for the first time), and moving methodically, and identifying issues, and trying to resolve them the right way. I’m reading and learning, and getting through things.
Thanks and I appreciate it. I have definitely used your link, and it has definitely helped. I’ve actually come a really long way. Unfortunately, what I’ve found at this point seems to be: “everything-broken.” I know that’s got more to do with my emotions than anything. It’s a lot. It’s what I signed up for and I’m stoked to be learning, but - like you - sometimes it makes my head hurt.I saw you had acknowledged my post with a like.
Your ongoing posts didn't indicate any continuity testing or acknowledge you were using the link. seemed more live power testing.
You would b surprised at how many people ignore help
If my link helped, great.
I understand how electrics is mindboggling when learning from scratch. I think it pays not to try to understand the intricacies of how components work, just knowing things have to b in an order and how to test a part will save a lot of headache.
Keep going, when I first worked on swapping a good secondhand loom onto my bike, sometimes I had to stop for a few days because my brain was actually hurting trying to relate a wiring diagram to the actual bike. Also I had to sort the differences between an Oceania 80SG to an American wiring diagram. A US 78 Special loom went on my 80 still a couple of gotchas.
Don't give up. I bought what looked like a tatty but complete and original 650D. I thought it was going to be a straightforward recommission. How wrong is it possible to be?Thanks and I appreciate it. I have definitely used your link, and it has definitely helped. I’ve actually come a really long way. Unfortunately, what I’ve found at this point seems to be: “everything-broken.” I know that’s got more to do with my emotions than anything. It’s a lot. It’s what I signed up for and I’m stoked to be learning, but - like you - sometimes it makes my head hurt.
Points. They look newish, but I had to pack it up before I could check the gap or guts around in there.Remind me again, this bike have points or an aftermarket ignition?
Rgr. But probably not until Saturday. I got music rehearsal taxi-duty the rest of the week.Tomorrows a new day.
First order will be to see if you have 12v at the coils... and go from there.
what?!? On the end that goes inside the engine?!?OMG... the spark plug has an aluminum cap on it...![]()
Thanks Jim. I did figure that part out, and went with resistance in the caps.Make sure you have either a resistor plug or a resistor cap... one or the other, not both. Give us the plug number and the cap numbers?
