So I’m so far from stock and spec on this bike what with the two into one intake manifold, one carb, open/slightly baffled pipes, uni air pods, gonzo ignition, etc, I won’t even bother you with the exact settings, jet size and air/fuel mix.(unless you ask
) . My question is how these motors behave under a certain condition, lean or rich. BS38 is the carb.
Timing, cam chain tension, and valves are dead on.
I have the bike idling well. Steady roll on the throttle off idle it takes off smoothly, sharp crack of the throttle it stutters once, kicks back through carb once, and then away we go. What is she tryin to tell me.
Another issue. Using the idle speed adjustment screw so I know it’s steady, I’ll bring the bike to about 1/3 throttle it will run steady for about 3 seconds than the rpm’s will begin to slowly climb to the heavens. Is this a lean issue? I wonder if the two issues are the same and the needle needs lifted some more but I am already on the lowest(richest) slot. Maybe a shim.
, but general rule-of-thumb is to keep going richer (main jet) until it gets worse, then back-up. CV carbs aren't known for liking "snappy", abrupt throttle opening - that may also be nature of beast, especially with that manifold
