nodwick
Hello all! I posted several weeks ago and got my bike running great. Got some good miles in. But now I'm having more issues.
I went on vacation and didn't ride it for 3.5 weeks and suddenly the carbs acted clogged. Okay this is expected. Even with the e5 fuel that "contains no ethanol" according to fuel companies I would expect this.
I'm having idle issues and I'm totally stumped. I can get the bike to idle fine and we'll but idle hangs a bit on decel and so then when I played with mix screws to get optimal settings they were showing me a clear indicator of -something- wrong I suspected a clog but a bit lost.
LH carburetor needs the mix screw settings at .5-1 turns out from all the way In
RH carburetor needs to be set at 4.5-5 turns out, the mix screw about ready to jump out of the bike!
I rode it around one day to see if that would clear up the issue and it did temporarily suddenly bike acted normal and started shooting on the right side indicating too rich (happy days) and the it started pissing gas out the LH carb intake for the last minute or two of my ride (
I took them off twice yesterday and throughly cleaned them using a generous application of STP.
Even after cleaning the results are exactly the same.
-Compression reads 130 both cylinders
-Fuel flows well from taps
-With these same jets the bike was running amazing until it very suddenly started acting like this
Checked the float valve and seat everything looked great and swapped out the pointy bit even.(Attaches to float)
-fuel fresh
-voltage from battery is strong
-tried different spark plugs and everything was the same (even when swapping plugs left and right)
-Fuel floats are set the same and have no cracks or anything and it has not been cold enough to freeze here.
-diaphrams have 0 holes and are very rubbery still. Although a couple crease marks but nothing to affect their operation.
but why would one carb be overly lean and one be overly rich
Today I'm gonna swap the diaphragms left and right and reclean the carbs again
Just trying stuff at this point.
I'm so lost. Anyone have any ideas and what would cause this?
-fuel fresh
