Hi All:
I was on another forum this morning and a question on this topic had come up so I wrote up a post and thought I would re-post it here to re-fresh the knowledge-base.
I wonder if this might warrant a sticky....
Pete
____________________________________________________________________________________
If you go to Partzilla.com - you can select your bike model and year and then pull up the parts fiche (aka exploded view / microfilm drawing) and get the OEM part number for every single nut, bolt, bearing, seal and engine or chassis part on the bike.
THAT OEM PART NUMBER IS GOLDEN INFORMATION!!
There are several things you can do with that OEM part number:
Pete
Pete
- You can see if Partzilla lists the part as available and at what price (they carry a huge stock of parts for even older motorcycles);
- If you click on the part number in the parts list beside the exploded view diagram, another list will come up telling you what other bikes used that very same part. (OEMs recycle a lot of their parts from one bike to another and so if you go into a dealership and say you need a footpeg bolt for a 1978 Yamaha XS650, the pimply-faced parts kid will likely say "We don't carry any parts for 41 year old bikes" - but....if you say "I need a footpeg bolt for a 2017 Yamaha R1" - he may have a box full of them. Many simple parts like fasteners have been used for literally decades - and have been listed under exactly the same part number throughout that entire period.
- Knowing what other bikes used the part that you are presently looking for means that you can go to a salvage yard and look at a much wider range of bikes than just yours.
- If you own a Honda (and I suspect that some of you might ) - you should know that a large percentage of the fasteners - things like nuts and bolts and those expensive little plastic push-pins that hold the fairings together are also used on Honda cars and they use exactly the same part numbers as the bike division. The key thing is that Honda car dealerships usually have a much bigger stock of parts than any bike stealership and they normally price the parts much lower than the bike division because the auto market is so much more competitive plus they buy in larger quantities. I got a whole bag full of plastic push-pins for my ST1300 at a Honda auto dealership for about half the cost my local bike dealership wanted. In fact, I found out later that those very same parts can be purchased on eBay even cheaper.
- The Partzilla parts listing normally gives the basic dimensions of things like nuts, bolts, bearings and seals and many of these are standard industrial items that can simply be purchased at an industrial supply house or on-line. The key thing here is that none of the OEMs actually make their own nuts bolts seals, bearings and washers - they buy them from specialty manufacturers and those folks sell to lots of other companies as well.
- You can check to see if someone might have that part for sale on the web: All you do is enter the OEM part number into your web browser search window. NOTE: Use only the part number / letter combination - no other words or modifiers are required. You might be amazed to find that somebody somewhere has got that very part either used or NOS and is trying to sell it at a great price. I got a nice NOS clutch pushrod for my 1976 Yamaha XS650C for $6 shipped using this method and it came unused and still in the original (but dusty) 43 year-old Yamaha parts package. The thing is that people go around buying up old stock from dealerships that go out of business or simply need to clean house - and then they put the parts up for sale on the web. In the vintage bike community, we use this method all the time to keep our bikes running like new.
Pete
