Finished the 750 Rephased Chop Build
United Kingdom
Hi Guys,
Well, after a long two years of working on my new chopper project, albeit I lost half a year to demotivation, I've finally pulled my finger out and got the bike finished. I've loads of pics of the various stages of the bike build, and the many one-off custom parts that were needed to complete it, so if there's anything specific you'd be interested in seeing let me know. For now I've posted pics from a photo session I had done, as I wanted some nice pics of what might well be the last chop I build, being too old to kick 'em over now.
So, a few words about what you're looking at.
I decided to use the Fenlands Choppers bar hopper frame, but in 32mm tubing as I wanted to run all the electrics in-frame where possible. I also requested a one-piece centre post and spine tube to assist in hiding the wiring. The front springers are my own design, after reading much material from several well known US based springer builders/designers. I've never ridden springers before so was a little apprehensive about what the final ride would be like, as in whether it would pogo everywhere and be a nightmare on our twisty lanes and lumpy bumpy UK roads. Hence the long nights of reading and designing the geometry to suit the geometry of the bike I intended to build, to try to avoid the white elephant. Anyways, now its done it's first 250 miles I can honestly say I had nothing to fear. The front end rides beautifully, no noticeable pogo-ing, real good in the twisty's and firmly planted right up to 85mph!! Well impressed with the springers. The springer legs are solid stainless bar and the yokes and pedestal are from billet 6061 aluminium. Being a hardtail and with our roads being so bad I decided on a well padded solo seat that has a mountain bike air shock whch has adjustable compression/rebound damping, so go easy on my back :) 16" powder coated rims with stainless spokes and Harley hubs front and rear. Lots of brassware, and anodised aluminium bits too, mostly machined by myself and a mate with a miller. The dummy oil tank, which houses the Axel Joost B-Box electronic controller and all the main electrics, is a flask from the nuclear industry and its unusual lid, with four milled out finger holds, inspired the detailing theme throughout the bike.
The motor is a 2F0 motor that has been fully rebuilt, and has a 277 rephased crank and XS1B profiled camshaft, a 750 big bore kit, enlarged valves and smoothed porting. It runs a Tri-Spark ignition and a Pipes and Stuff PMA and has Heiden's 5th gear overdrive pinion. I'm running an 18/31 setup on the final drive too, so it has a great throaty low revving note with those 41mm slashcuts which, surprisingly, have not given me any trouble with carburation. The twin VM34s, with velocity stacks and fine gauze screens, run beautifully right through the throttle range with none of the stuttering and low to mid-range problems that plagued me on my 750 270 rephased street scrambler. The slashcuts have a 50mm length of 35mm pipe at the start of the headers and this early narrowing would appear to be acting rather like torque inserts, so happy days. I decided to tart up the motor with a clutch window, for the hydraulically operated 7 plate clutch setup, running EBC performance frictions with EBC uprated springs. No slip whatsoever. And, surprisingly, no issues with oil messing up the window!! Again, happy days :) Also stuck a window on the genny side too. Hydraulic clutch slave is 2009 Aprilia Tuono, with a Brembo PS13 MC. Works soooo smoothly and light. The motor has the Smedspeed upgraded sump plate with the canister filter, as has my street scrambler bike. My arthritic knees won't allow me to kickstart a bike anymore so stuck Smedspeeds uprated four brush starter motor on it, and fitted a 280CCA lithium battery to give it plenty of umpf. Bike starts first stab of the button, hands off the throttle. The throttle is a 2-1 cable setup, using the original Yamaha Throttle tube and my own one-off aluminium throttle assembly switch block, designed to mirror the internals of the Yamaha block, so the travel would be right for the Mikuni's.
I've painted the bike in black, pearl white mixed to give a cream look, red pinstripes and all accented with 24ct gold leaf. I had to repair a villager's Indian Scout tank recently, which had the black/pearl white/red pinstripe Indian Iconic paint scheme (only one with this paintwork I've ever seen in the UK) and I fell in love with it, hence my choice. Never done gold leaf before, so avoided engine turning, as if you get that wrong you're back to square one.
Anyway, hope this hasn't been too long-winded and thanks for your patience reading it all. I just wanted to share my road to happy days, of which I know this bike will provide in abundance. The bike's called Fonzie by the way, obviously, haha! As I say, if you'd like to see any other pics of the build process, let me know and I'll stick some build pics up.
Like the fonzie bike a lot.
How did you do the clear clutch and rotor?
Machined up a mounting ring from billet aluminium. Then trammelled out the same size hole in the outer cover (the small raised stud in the casing, that is the pressure plate 'stop', centres the tramel). Once stitch welded into the casing, to avoid too much heat build up, I 'sealed the inside of this joint with Por Patch (only has to prevent an oil leak). Then I used a 6mm ring of stainless to mount the 4mm perspex window. Between the stainless rings and the aluminium mount ring I put a gasket, which I made from a sheet of 0.5mm thick silcone sheet. The rings are fixed using ultra-thin socket head screws.
To weld up the aluminium mounting ring I had to set up a simple jig so that the ring sat exactly parallel to the clutch pressure plate/ casing mounting face and also sat the right distance from the pressure plate for clutch clearance. Last photo is my setup
Hi Guys,
Awesome build!
That's nice. Are you the first to do a see threw clutch for these? Just Curious if you'd charge to do one but can't afford it now?
I think I'm actually doing a chopper instead of brat style if I get this other frame for title reasons. I feel like if these bikes came as choppers people would be adding shocks and swing arms like the opposite but who knows. I haven't got frame yet but feel like I'm gonna have to weld on a rear brake to work with stock rim. Or anyone know if a forward control kit brake just mounts up or welds up where connection. Seems like tc bros sells a connection piece for 70. It would be cool to go harley wheel route but maybe later as can't afford it. See you have rear caliper brakes.
