Miker
My bike appears to run fine and idles good but if I remove the left spark plug lead it makes no difference to the running. If I disconnect the Right lead while idling the engine stops. If I keep revving up then disconnect the left lead it will run but as soon as I let the revs off it conks out. It has spark on the left side and I have changed the leads and plugs over with no change. Am I wrong in thinking it should run the same on either cylinder and you should notice a change if you disconnect one lead?
