Scooterbrain
1970 650
Guys I have been reading here for weeks and still not sure what the issue is here. I pulled the engine out last week and while the First gear Fork looked bent, even looked like a slight twist maybe.When I straightened it it was too tight so I restored it to where it was and it shifted fine on the bench.
I did find that I has omitted the second shim that goes behind the Clutch Boss. Now it is "Shim, Flat Bearing Shim. I also found that my manual only showed One ball used with the Clutch rod instillation so I corrected that to a ball at either end of the Clutch Rod.
It shifted like a dream in the bench. Went all through the gears up and down 4 times and said OK. When I hold the Clutch assy in both hands I can lust barely feel it move a tad when I try to rock it back and forth so that felt correct.
Once it was back in the bike "Not Running" it shifted all gears just fine I could shift through all gears through the entire range although I did have to move the rear wheel a time or two to get an engagement and snap it went right in.
Then On the Bike lift I cranked it up and ran it and I had no issue at all getting it to shift into any gear but it did seem like I had to brake to stop the rear wheel from turning while I was in a gear and had the clutch pulled in. I figured cold oil and clutch so I figured it would be OK. NOT !!
I cranked it up and selected first and it went right in. I drove 10 Feet and it jumped out of First. I try to again select First and you can hear the Three Dogs trying to enter the Three corresponding holes and it just goes clunk clunk and wont go in.
I cannot see any wear on these gears at all But I also do not see the bevel or taper that guys are talking about restoring to these gears. The Shift Forks have a Full Pad look and seem to have no wear. This bike had this issue when I bought it and I had assumed that it might be the broken end on the shift arm that engages the end of the drum and that is now New and it is centered per the diagrams with equal distance left and right and the lock not it tight. Only thing I wasn't happy about on reassembly was the slop in the First gear on the shaft and I resisted my thought that I should add another shim there behind the snap ring.
All I know to do now is go for a new First And Fourth gear and a New Fork . ???? I am glad you guys are here and I did read till my eyes were bleeding before posting this.
