1. Dismiss Notice
    Dismiss Notice
Flat track project
Discussion in 'The Garage' started by Pipes, May 8, 2020.
  1. Jim
    About 77 kg.
    Pipes likes this.
  2. Jan_P
    Jan_P XS650 Junkie
    569
    837
    93
    Sweden
    Thinking out loud
    That brown strut looks weak . ( even though 2 of them )
    Assuming the bike weighs 250 kg --- half of it back
    When moving the swing up and down there is a rotating point at the engine ..the vertical force ( perpendicular to swing ) in the brown 4 - 5 times the load on the wheel point of the swing
    And since the strut is sitting in an angle the total force in it is larger.
    Apologize if I have not read good enough or not understood the picture or sketch or measurements
    And if this is a proven working setup.
    But my first spontaneous hunch would be bigger dimension there than the swing
    as it looks in the picture it is smaller
    If you like and it is not done already you can put up more like a drawing perhaps someone can calculate a little as to forces
  3. Pipes
    Pipes XS650 Enthusiast
    53
    160
    33
    Uk
    Hi Jan P ..
    When you say 'brown' strut are you referring to the top mount??...if so I know what you mean.The mount has been welded since this photo including a plate over the top tying both sides together...There is always the option of placing a vertical gusset on top to increase stiffness perhaps?
    MaxPete and Paul Sutton like this.
  4. Jan_P
    Jan_P XS650 Junkie
    569
    837
    93
    Sweden
    At # 3 posting lowest picture 6 o clock
    the strut in ca 45 degrees
    # 15 posting the brown there in the moving picture
    Just a feeling , without measurements and pictures ---- take it for what it is worth
  5. Pipes
    53
    160
    33
    Uk
    Oh ok...the threaded bar connecting the linkage to the swingarm.In the UK we sometimes refer to them as 'dog bones' due to there shape.
    Yeh those are just used for mock up and I now have some solid stainless steel bars turned up to suit the rose joint bearings.These are slightly bigger than the ones in the pic but I will take your advice into consideration.I may make some beefier ones,after all,I wouldn't want those to fail :eek:
    MaxPete, YamadudeXS650C and Jan_P like this.
  6. Pipes
    53
    160
    33
    Uk
    Well,that's xmas over and done with for another year..I hope you all had a good one and stayed safe :geek:
    Today I popped to my workplace to do some more to the bike.We are all off for a week so it's nice and quiet and I have the place to myself.
    My new tyres arrived a few days ago so yesterday I fitted them to the new rims,very carefully I might add and fitted them to the frame.This is the first time the frame has been out of the jig properly and standing on its own two feet,or wheels in this case...
    I had already made some spacers to take up the gap between the supplied bearing spacers and the fork leg and swingarm ends.It turns out the wheels do not sit central in the frame so I will have to re-measure and make new.
    Before fitting the wheels I had to redesign the lower bearing tube which supports the suspension linkage as my original concept was a bronze bush but after giving it some thought I changed to a needle roller/bush set-up to match how the lower shock eye is designed.It will work much better but just requires more accurate fabrication.I machined a temporary alloy 'bush' while I am working on the bike so I do not commit to fitting the new needle bearings before getting the frame lacquered/painted.
    Once the suspension was fitted,along with beefier link bars,I put the wheels in with the new spindles/axles.These new stainless spindles were made by a local firm as I wasn't confident in doing it myself on my little lathe and they could do a better job of the threads too.The rear spindle has threads both ends held on by two stainless steel nuts which I turned down a little and drilled them to give them a different look and applied a little heat to turn them a nice dull gold.Both spindles fitted the bearings a treat which was good as they cost me a lot more than I had planned,I am trying to build this bike on a budget afterall....
    I also took a pic of the yokes after getting them blasted and to be fair I am happy with the coarse finish giving them a sandcast look.
    I took some pics of the rolling chassis before the seat and tank were fitted and I am happy how it's going.The tank seems to suit it even more now which has always been in the back of my mind as to whether to use it or not but I think its going to stay now.
    134171782_10217089146892453_3999051453003727559_n.jpg 133986204_10217089149292513_404868558830826542_n.jpg 133792800_10217089148892503_6943480773116283199_n.jpg 133765514_10217089149892528_1669494482275393800_n.jpg 133308934_10217089151092558_940921257591255664_n.jpg 133695783_10217089147812476_1934699847029429993_n.jpg 133652856_10217089148612496_3674607609556504650_n.jpg 133685919_10217089151372565_1926800765920647411_n.jpg 133698197_10217089151852577_8519483731843749550_n.jpg
    Rhy650, MaxPete, Team Junk and 6 others like this.
  7. MaxPete
    MaxPete Lucille, Betty, Demi & Gretel: I ask, THEY decide. XS650.com Supporter Top Contributor
    That looks a bit lightly constructed to me I'm afraid.
    In particular, if those Heim joints are 1/4-28UNF - then they are only rated for about 2700 lbf static (see the attached document below).
    I don't know the details of your suspension geometry but I'd bet it will generate a lot higher loads than that - particularly when it is working hard on a bumpy road.
    Pete
    arcticXS likes this.
  8. Pipes
    53
    160
    33
    Uk
    Maybe you're right but I reckon the rose joints should hold up...one of my other bikes (Suzuki) has links just like these and that thing weighs a ton and has a much longer swingarm,;)...if for any reason they do not hold up then they can be changed.Bigger bikes have been using them for years.(The second pic is generic,not mine)
    MaxPete and Jim like this.
  9. MaxPete
    Okey doke.
    Team Junk and Jim like this.
  10. Pipes
    53
    160
    33
    Uk
    Do not get me wrong,I appreciate any advice given...Everyday is a school day...looking at the data on rod ends the aircraft type seem to be the more suited to the application.I shall do some research :thumbsup:
    It seems steel on steel rod ends are much better dealing with shock loads...I have steel on bronze at the moment.
    Jim and MaxPete like this.
  11. Jan_P
    Jan_P XS650 Junkie
    569
    837
    93
    Sweden
    I like your style in terms of friendly openness ...by the work you do it is evident that you are very competent.
    And not many can that better.
    Something that perhaps is worth consider .. If not already done ... bare with me if it is already analyzed
    I have googled a bit on Frames
    Usually the front has 2 downwards tubes or an extension out from a center vertical plane
    XS650 --> XS650
    Honda -->CBR
    At least this gives a greater transversal stiffness ( If you put the frame on its side on two blocks and step on it in the middle )
    There are some single tube fronts perhaps mostly hard tail which I believe seldom are driven hard
    There exists a few flat track bikes with one front tube. Then by the looks of it a little larger diameter.
    Material as wells as tube wall thickness affects .And this can already have been analyzed
    I don't think the XS 650 frame are extremely solid.
    It also comes down to styling preferences and expected driving style. Take this for what it is Worth
  12. Pipes
    53
    160
    33
    Uk
    If I am being totally honest I have only researched information on frames through the net and a Tony Foale book I once owned.I wouldn't say I am making it up as I am going along but then again it does have little bit of 'lets see how this goes' :D
    The frame you see is based largely on the Mule XS's which are quite similar ( I believe Mule have posted on here before) although they do have a different arrangement for the swingarm mount.I went for this look because I thought it very unique.As for the monoshock this was chosen again to be different and have some degree of engineering thought gone into it even though it was more of a challenge than twin shocks...I guess the key word in building conventional bikes is just that..'conventional'...I have built various bikes/cars but where I have done the engine on one I have modified the frame on another but only to a point.This build I thought I would do as much as everything as I could.I have never built a frame from scratch and thought 'what the hell'...
    The engine is being used as a stressed member I suppose just like my 1995 Ducati I once owned for many years.That bike literally had everything bolted to the engine and had no undercarriage framework yet Ducati got it right as it handled impeccably but then again they have had years of research as success with it.
    This doesn't mean mine will work...it may be a total failure but I hope not.The bike isn't going to be raced,only road ridden and it won't be abused.
    I guess I could fit lower frame rails to increase some stiffness but I really want to keep the single down tube as it is but if i really need to then so be it.Again I appreciate all advice if you guys have any...I am always open to suggestions even if I do not take some of them.I am by no means an expert and there are far more intellectual people out there than me :lmao:...Cheers :thumbsup:
    YamadudeXS650C, Raymond and Jan_P like this.
  13. Pipes
    53
    160
    33
    Uk
    I must try harder to post on time :p
    Anyway...weekend just passed saw me assembling the engine with the new 750 kit from Heiden Tuning.It went together really well and I am impressed with the quality of the barrels.Along with the kit went a new timing chain and tensioner guides.
    The only mishap I had was a fault on my behalf but when I turned the crank to tdc both pistons raised ok but a little while later I needed to turn the crank some more and only one piston went down...:eek:...my surprise was quickly followed by a forehead slap moment as I realised I must have missed the con rod hole as I pushed the wrist pin through (story of my life)...I had a little giggle then corrected my mistake.
    I did get around to putting the head and chain on but it seems the engine is missing a couple of dowels so the torque down will have to wait till the new dowels arrive for the rocker box.
    While I am waiting I took some advice from the forum and strengthened the lower sump filter too.
    One step nearer.
    143890055_10217309991733436_8538690917609430596_n.jpg 143777116_10217309991253424_194640145592502854_n.jpg 144083515_10217309992053444_8067189464452232415_n.jpg 144045170_10217309991453429_6733638485151238255_n.jpg 143871501_10217309990293400_8136737144716360086_n.jpg 144255165_10217309992333451_8215084351409884037_n.jpg
  14. Jan_P
    Jan_P XS650 Junkie
    569
    837
    93
    Sweden
    Impressing
    Not sure what is right or wrong but I am a bit old school with oil.
    Rather to much than too little
    At this point in time I would keep oil in the cylinders .
    On top of the pistons.
    Someone surely will correct if that is wrong.
    gggGary, timbeck and Jim like this.
  15. durgam_K
    durgam_K XS650 Addict
    I love the mono shock.... I believe I will be going that direction on my next build.....
    Keep it up.
    gggGary and Pipes like this.
  16. Pipes
    53
    160
    33
    Uk
    Jan P you are correct.it is good practice to oil the bores on assembly.I did oil them but just enough to aid the pistons.
    gggGary, timbeck and Jan_P like this.
  17. Raymond
    Raymond XS650 rider & fettler XS650.com Supporter Top Contributor
    Loving this build.
    YamadudeXS650C and gggGary like this.
  18. Pipes
    53
    160
    33
    Uk
    Ok,so today I managed to finish the top end,getting the thing torque up,valves adjusted etc etc..I have at last received the final clutch shim after 2 months of waiting and put that all together.I am going to make some new plate fasteners as the original screw heads are not in the best shape.
    I now can take a measurement and shorten the actuator rod seen sticking out of the drive side casing for the slave cylinder,then I can look at making some exhaust mounting flanges like the inlets.
    I also trial fitted the stainless steel kickstarter I made and it works a treat and it still uses the original shaft mount and plunger.
    To match the alloy cover I made for the stator case I fabbed up a couple of cam covers which fit nicely but just need a little tweak around the sparkpugs.All the big things the engine needs to be almost ready is the ignition and carburation when funds allow.
  19. Jan_P
    Jan_P XS650 Junkie
    569
    837
    93
    Sweden
    World Class
    A short comment .. the stock alternator cover is slightly convex outwards... But I assume you have checked the Clearance. On the Inside
  20. Pipes
    53
    160
    33
    Uk
    Yes Jan you are correct..I noticed this the other day.It is close to the stator retaining nut and has had a very small amount removed from the inside.:thumbsup:
    gggGary and Jan_P like this.
Share This Page
