Flat tracker build. ( It was suggested I put this in a thread in case anyone wanted to follow it)
judd
West Yorkshire
I'm just getting the front and back end sorted at the minute,rear is sr250 hub with cush drive to be converted to a disc brake and a 17" rim. Front end is R1 with 330mm Zx10 discs on an old gs750 hub also getting a 17" rim ( quite problematic) I'm going to have to get some new rotor carriers made to my spec🤔. It's just a dry build before getting stripped and sorted, no idea if the engine runs or not. Everything came in a load of boxes! I'm undecided whether to build a new lightweight frame (Reynolds tubing) or stick with the original as the standard frame is extremely heavy.
Thanks for any interest and I'll probably have a few questions 😄
Nice. The cb750 sohc hubs lend themself to modification quite well. I used a set of zx6 big piston forks, and modded the cb hub to use the kawasaki bearings and spacers with a ducati/later sr400 rotor.
The kz750b rear hub works well too. 20mm axle, just needed the sprocket spaced out a sprocket width.
*edit* depending on where you are buchanan spokes can set you up with a rim and spokes, or if in WA near Auburn there is a shop called "the wheel master" who can do custom spokes and rims.
I used a KZ750B hub on my 650 except for being 40 spoke not 36. I will be watching has I also am doing a tracker project
Love the JMC swing arm I put one on my Kawasaki Lawson Replica (that I later stupidly sold) . You will struggle to induce any flex in that with an XS.
I like the drum to disc conversion idea it widens the scope of donor hubs and the cush drive is a great bonus.
Looking forward to updates.
Thanks for the reply OD. I've finished the disc conversion this morning and had to bore out the axle holes on the JMC s/arm to 20mm,for some reason they were 17mm . Just got the axle spacers to do and sort the sprocket alignment. I think I need a 31 tooth sprocket to keep the gearing for 17" wheels unless someone knows better.
Excellent, thanks for that. Just in case anyone is wondering I got this bike in boxes from the widow of a friend of mine and she just wanted the garage cleaning out. As far as I know there is supposed to be a complete bike,3 sets of carbs,3 sets of forks (only one good), electronic ignition and a load of other stuff I haven't even looked at. There's going to be lots of standard stuff left for anyone who wants it 😁
Thanks for the reply OD. I've finished the disc conversion this morning and had to bore out the axle holes on the JMC s/arm to 20mm,for some reason they were 17mm . Just got the axle spacers to do and sort the sprocket alignment. I think I need a 31 tooth sprocket to keep the gearing for 17" wheels unless someone knows better.View attachment 378715View attachment 378716
I switched to Ivan's high ratio primary gears with 17s. I think I was running 18/39 stock with the 17s and it topped out early.
Had the same problem with the Radent sing arm, had to have everything bored\milled out to 20mm. The shock spacing use wider so I just spaced the shocks out at the frame. Probably use the Radent swing arm on my tracker build unless I find something I like better. But will move the shock mounts. I like what you’re doing with this build. Still looking for a metal tank I like.
They just seem a bit 'Heath Robinson'and apparently they're bolted together as a sort of vibration damper. I thought I could mill some out of a piece of solid aluminium and rubber mount them.
Go for it @judd; they are a bit agricultural looking as standard. But not really seen with the tank on.
