judd
I probably will, I wondered what the vibes were like without any on.
Cheers
Cheers
Not sure of the validity of solid head-steadys that are then rubber-mounted, given that the rest of the mounts are solid. Now if all of the mounts were rubber-mounted, that would be a different story. Given the vibration produced by the XS engine, that would be an interesting mod. I think that someone must have done this somewhere along the line.Is it worth making solid head steadys mounted on sleeved rubber mounts? Are they necessary?
Agree. There's two aft mounts, a lower, the front and lastly the top, for a total of 5 mount points. Rubber mounting just the one mount would likely make no difference in vibes because there's still 4 mounts transmitting vibes to the frame.Not sure of the validity of solid head-steadys that are then rubber-mounted, given that the rest of the mounts are solid. Now if all of the mounts were rubber-mounted, that would be a different story. Given the vibration produced by the XS engine, that would be an interesting mod. I think that someone must have done this somewhere along the line.
Unfortunately it only covers 16" and 18" wheels.There is a table - I think @5twins put it together - that gives gear ratios for a whole range of front/rear sprockets and wheel sizes?
5 points.I was considering the 4 mounting point on the engine. Thanks for the chart![]()
That's been my impression as well... can't really see why they need to be made up of 6 individual parts. The one thing that I can see, having recently installaed an engine, is that the OEM design allows for a little "wiggle room" when setting the 5 mounting points, as the weight of the engine is supported by the other 4 mounts. There may be more engineering to it than that, my thats been my conclusion.Sorry a bit of a misunderstanding, I meant a sleeved bobbin each side of the mounts on the top of the engine. The top mounts aren't engine mounts just head steadys. Just a thought as the original ones look like an afterthought
Interesting perspective and possibly part of the overall design intent of unifying the frame and engine as a solid mass... Regardless, is there any reason the 6 bits that make up mount #2 could not be replaced by two alloy brackets of suitable mass and rigidity?I've always thought of #2 as being more of a frame headstock steady than an engine mount....
Hughes hand built used to sell a set like thatInteresting perspective and possibly part of the overall design intent of unifying the frame and engine as a solid mass... Regardless, is there any reason the 6 bits that make up mount #2 could not be replaced by two alloy brackets of suitable mass and rigidity?
