Pat D
So back in the fall I ordered parts for a front end refresh this spring. Fork seals, dust covers, and springs. I ordered based on my application, '74 TX650A. While I know that parts get swapped over time by previous owners, my forks seem to 100% reflect what the '74 parts fiche breakdown shows. But the springs I ordered are looong. They come right to the top of the fork tube, whereas the old springs allow for the spacer to fit nicely with no preload at all. Old springs are roughly 15 1/2"(390mm), while the new ones are roughly 19 5/8"(495mm). The spacer is roughly 4".
So- do I just toss the spacer? That will allow just a touch of preload. Installing the spacer means compressing the new springs 4" to get the cap on- seems like a LOT of preload, with a significant degree of difficulty getting the cap on w/o cross threading it or otherwise boogering the soft aluminum threads. I've searched about every thread I can find on this topic, and it "seems" like in most if not all cases there is minimal preload/minimum spring compression needed, the spring/spacer combo seems to sit right at or below the top of the fork tube. I don't remember who I bought the springs from, so return is not really an option. But I for sure did order for my application.
So my options appear to be, 1. Eliminate the spacer. 2. Cut down the springs to allow for the "proper" amount of preload (which is???) with the existing spacer. 3. Cut the spacer down (don't want to do this, part is NLA) to allow the as yet unknown amount of preload. Other than cosmetics, the bike is bone stock, I'm not trying to lower it or customize/tune the suspension in any way. And it's hard for me to imagine the factory springs have "settled" 4" over time, the coils appear to have the same spacing as the new springs.
Any thoughts? All input much appreciated!
