IMO, 35 mm, (77+84) forks are going to b better than 34mm forks.
34mm forks work just fine. Unless you ride hard the noticed difference between 34 and 35mm the average rider isn't going to notice much, if at all. Totally depends on your riding style, a fork brace will stiffen it up if required.
76 forks will swap in the mag wheel and spacers as a straight swap. Won't take your 80 caliper or roter, will have to stay with the 76 caliper and roter, 76 rotor bolts to the mag wheel
Need a 74-76 triple tree but have to have a 76 crown so your 80 gauge bracket will bolt straight on to it. The 76 crown doesn't have a provision for the 80 ignition switch though. That would have to b moved.
So you need.
74-76 triple tree
76 crown for the tree
73-76 rotor and caliper
Change ignition switch position.
Some minor wiring changes
Fork brace if required.
Personally I don't mind the looped fork races Mike's sells, or look for a type that goes across the forks at the dust seals for minimal look
