I have not ridden my xs for while now, I can not remember if the indicators self cancelled. I probably pressed it to cancel the flashing. After frank's discovery, this could be the reason for mysterious non running situations. As it has been in there for more than 40 years, I think I will swap it out.Aye, the flasher cancelling unit.
Great concept except you almost need to know how many revolutions have to have turned before it shuts itself off. Why are my turn signals shutting off before I make the turn? Speedo reed valve and the cancelling unit.
Some turns I need to give those behind plenty of time for my intent, and no, I haven't changed my mind about turning at the last hundred feet or so.
Manual, turn them on when needed, turn them off when done.
Yes I simply removed the self cancel unit (and the reserve lighting unit) with no ill effect.I had a cursory look on mikesxs for self cancelling units and there is non! Jim says one can just remove it, a few posts ago. is that the reality, no problems?View attachment 334652
Yes, same here. I have removed all the near 50 year old electronics from my bike. I don't need anything to be a potential reliability issue down the line if it's avoidable. (The one exception for me is the start motor safety relay. I have kept the original one. I would like to replace that with a modern equivalent one day. But I do have the kickstarter should that relay prevent electric starting one day. So it's pretty unlikely that's going to prevent me getting home one day).Yes I simply removed the self cancel unit (and the reserve lighting unit) with no ill effect.
Click to flash, click to stop flash... Simples.
I’ve been riding these Yamahas for over 40 years. I have been trained by the self cancel feature as designed. If I give a long signal, I’m prepared to reengage. From stopped, I know I’m going to use my thumb. Manual signals? I’m going to be the guy driving 5 miles with a signal flashing. It’s not a system that is typically troublesome, until you try to run it with LED lamps.I really need to unplug my self cancelling unit as it often shuts the turn signal off before I even come to a stop
With over 165,000 miles on an XS, I get pretty close most of the time.It's a game to time it just right, if it quits blinking just as you pull away from the corner, WINNER!
Adam, when you removed the reserve lighting unit, did you have to put in a jumper wire somewhere? Where?Yes I simply removed the self cancel unit (and the reserve lighting unit) with no ill effect.
Here's a post from me a few weeks ago answering that question -Adam, when you removed the reserve lighting unit, did you have to put in a jumper wire somewhere? Where?
