Steve C
Have you tried rigging up a bench bleed system? Brake line looped back and into the MC reservoir?
The thumb over the banjo port trick usually works to get things going.
I know that once it's bled you should see the reservoir level drop as you release brake handle; as the piston draws in a fresh breath of brake fluid. So that porting in the piston has to be open and clear. If the piston does not allow make up fluid from the res. into the piston/cylinder and just bounces fluid back and forth, it'll never push fluid down the lines and bleed. Also, you sure the piston is returning all the way against the snap ring with some free play at the lever? I've had that foul me up too. If the piston cant release all the way, it may not draw in fresh fluid from the res.
Usually this goes just fine. Been there tho. Its a bitch.
