I've also seen the NO stainless advisory. Since the anode is the COLLECTOR here I'm thinking problems will be minor, haven't seen anyone screaming about derusting chrome parts. Yet the cathode is where the molecules are REMOVED.
I've done "some" electrolysis. some tips?
Don't let line of sight fool you; cloth, various plastic meshes are completely transparent to the action. the action is very much cathode/anode distance sensitive. so an anode grid or "curtain" that surrounds the part will greatly improve uniformity of action. Fairly flat parts, a sandwich
Bare steel plate anode on the bottom, a plastic mesh (think a sheet of "scotch Bright" type material) separator, the part, a second section/plate anode, will derust both sides of the flat part. for gas tanks I place HEAVY bare wire inserted inside tubular webbing bent to fit in the tank and extend toward the bottom/ rear of the tank.
Two legs, one on each side of the tunnel would be ideal. The rust will end up trapped inside the webbing and come out when you remove the anode!
Some of my electrolysis experiments and usual suspects :^0 weighing in.
https://www.xs650.com/threads/battery-box-rust-whats-best-way-to-deal-with-it.43213/
