I am on my 3rd set of Shinko 777s on my Roadstar. There are a good tire for me and have never made me feel awkward in any riding condition or emergency.
JB Weld fix’s everythingMost madness things have been bit n pieces elsewhere. It's really not needed much work the last few years..
Recently a carb started pouring gas, I "found" the problem, was a some sort of debris stuck in the float valve. But a little bee was buzzing 'round my skull that there was more to it. Took it out for that "last long fall ride" and part way through she started dumping gas on the ground at stops. I kinda suspected something wasn't right to have let bug parts into the float valve, so this time drained the fuel out of the tank and sure enough the petcock stand pipe/screen was just laying in the bottom of the tank and a dead bug or two had got in the fuel system and starting messing with stuff.
That tank is VERY clean inside but had spent some time hanging in the rafters, mebby with no cap on it. Didn't hurt to go through the petcocks clean and fix a couple things. I'll have to order some o-rings cuz I used up all the #29 from the red metric o-ring box on other petcock installs. This tank had been on the 79 survivor when I bought it and just grabbed it for madness to get better range on a trip without doing an R&R.![]()
Sometimes the screen is a loose fit in the petcock, but this one is a tight fit, had to tap it into place. Suspect a PO had it apart and didn't get it seated well.JB Weld fix’s everything
I ended up replacing my vacuum petcocks with simple manual ones. My original petcock screen did the same thing, the new manual ones each have little separate screens.Sometimes the screen is a loose fit in the petcock, but this one is a tight fit, had to tap it into place. Suspect a PO had it apart and didn't get it seated well.
Funny thing is this tank has been on madness for several years with no issues.
It has a significant todo list while it's on the lift. (don't they all?)![]()
That's why I added an additional filter down the line. But they went on pretty tight when I installed them.Reports aren't good on those little separate screens. They fall off, fall apart, or both, lol.
After 3 years and 4700 miles the Shinko 777 Bias ply was a goner, like all my tires the middle was bald, plenty of edges yet.Wow has it really been that long since I've posted in this thread? So met Madness at the VYR and rode her til her panties were soaked loaded her on the trailer with WJL, stopped at JRP1s place, then Barber, and on home. Rode her a few more times last fall and a couple times this spring, she was really needing a rear tire, 2800 miles on a Pirelli 130/70/18 bias ply Sport Demon that was aged out AND worn out, used it for the iron butt and VYR, center was bald.
Really wanted to use a radial cuz the front has been a Michelin 110/70 radial, this will be rear #3 with this front, going strong, just a little cupping. didn't find any 130 70 radials so pulled the trigger on a 140/70R18 B Shinko SR777. This is a reinforced tire for heavy cruisers, with the WM5 rim, 3", the tire's a bit crowded but still in "allowable" rim width. Recommended rim is a 3.75", profile mounted it looks more like a 130/80 but it went on and had plenty of room to the chain.
View attachment 169015 View attachment 169012 View attachment 169018
after 50 miles of back roads,
View attachment 169013 View attachment 169017
our rough pavement and the amount of deer out at dusk kept me from boy racer antics. I put in about 32 PSI and it thought the ride was quite pleasant seemed more plush than the Sport demon, no wiggles or funny moves. Bike felt good and stable.
Comparo to the Norton with stock rubber.
Kinda like the look.
bought on Amazon, kinda of funky ad, description, tire build date is 02/2020 so nice n fresh. $100 to my door.
Keep the sticky side down!
Got the Conti Road Attack on.
Before; (when the last tire was new)
While the wheel was off decided to made some chips.
sanded the well used rotor with a flap disk while spinning in the lathe
Started drilling, one 7/32 bit, 96 holes, no pilot drill, no sharpening needed. Very light chamfers, with a 5/16" bit in the battery drill.
Bit of paint, done and back together.
After;
Then had go ride horseys, a "test ride" later
Yep.Well the poop that came with the bike
claims it's a Bob Bertaut built 750 motor. I see some fancy parts inside the valve covers.
When I got it it was running VM38s and megaphones on 1 3/4 pipes. it was a dog til 5K then I was lucky to shift before blowing through redline.
I kinda detuned it with smaller carbs and real mufflers but the motor's untouched.
View attachment 247027View attachment 247029
Those VM38's are still around in the SOIR.
