Increasing the load on a PMA is actually a good thing if you don't exceed its output. Less work for the regulator, and the power is actually doing something useful.
Shunt regulators often fail due to heat. The power they are dumping to ground is like a controlled short circuit. The regulator is controlling that circuit, hence it is generating lots of heat during it's operation. The stator is also generating lots of heat since a PMA generates maximum power at all times due to the fixed magnetic flux from the permanent magnets. You need high quality components to deal with this heat load. The race to the bottom to source the cheapest components possible is most likely why these units fail, and why OEM Honda regulators are still working 40 years on. There was a guy nicknamed Duaneage at the GS Resources website who had a decent one man operation acquiring and reselling Honda regulators to GS owners whose regulators had died. They worked the same way as the OEM Suzuki units, but were far more durable. GS Suzukis had PMA alternators and were prone to failing charging systems. My 550E had me doing a few epic pushes. There was no Internet (for me anyway) back then, so I just went to the local salvage yard and bought another Suzuki unit. There is a section on the GS Resources called The Stator Papers that is excellent reading for anyone wanting to learn about PMAs, failure modes, how to troubleshoot, even how to rewind your own stator.
Some think buying a MOSFET regulator solves all their problems. To be sure, it is a superior design, as far as protecting the regulator goes. If it is a shunt regulator, it is still just dumping power straight to ground and doing nothing to ease the heat load on the stator, which is still generating maximum power at all times.
The advent of series style regulators has been a godsend for GS owners. The most popular one is the Shindengen SH775. It is found standard on Polaris side by sides, and some Can-Am products. You used to be able to pick them up pretty cheap second hand. You can buy them new of course, but make sure you are getting the real thing, as there are counterfeits being sold claiming to be the real thing. Other options are the Cycle Electric 600 series for Harley Davidsons, and the Compu-Fire 55402. The SH847 is another good one. They came stock with the latest DL1000 V-Stroms.
You can buy this OEM Triumph set of leads to acquire the proper plugs for an SH775.
http://www.adeptpowersports.com/oem-parts/triumph-link-lead-regulator-t2500676-part.html
This 50A series regulator fur under $100 would be overkill, but do the trick easily.
http://www.adeptpowersports.com/oem-parts/polaris-regulator-3ph-50a-series-hispd-4016868-part.html
