After thinking and .. I started to google and AI has a possibility to hack in questions
Not saying it is the answer but it is interesting Amazing really.
4. Internal Shift Fork Jammed (Worst Case)
If the external components under the clutch cover look absolutely perfect, the issue is inside the crankcases.
- The Symptom: A bent shift fork or a worn gear dog slot. If a previous owner forced a downshift at too high an RPM, the shift fork that slides the 2nd/3rd gear cluster can bend. It will hit a "hard wall" because the bent fork is binding in its track and cannot physically slide the gear over.
- The Fix: This requires splitting the engine crankcases to replace the bent shift fork and inspect the shift drum tracks for deep scoring.
Next Steps to Diagnose:
Before splitting any cases, remove that
right-side clutch cover.
Once the cover is off, let me know:
- Are all 5 pins on the shift star tight and sitting at the same depth?
- Can you manually rotate the shift drum smoothly using a wrench on the center bolt of the star wheel while rocking the rear wheel?
This will immediately tell you if the blockage is
external (easy fix) or
internal (requires pulling the engine).
Write in the Question
Because the shift drum is
difficult to rotate manually with a wrench, you have isolated the issue inside the crankcase. The "hard wall" you feel is a mechanical jam affecting the drum's rotation or the sliding gears.
1. Identify the Internal Root Causes
Since all five pins are intact on the star wheel, the resistance means the drum or its attached components cannot move.
- Bent Shift Fork: This is the most common cause. If the motorcycle was forced into gear or downshifted hard, a shift fork can bend. A bent fork binds in its groove on the gear cluster or jams inside the track of the shift drum, acting like a wedge that locks the drum in place.
- Worn or Damaged Shift Drum Track: The tracks machined into the shift drum direct the forks. Over time, or due to debris, a track can develop a severe burr, gouge, or crack. The fork guide pin hits this damaged spot and stops entirely.
- Interlocking Gear Dog Jam: The dogs (protrusions) on the sides of the gears slide into slots on neighboring gears. If a dog or slot is badly chipped, mushroomed, or deformed, the gears cannot slide together.
- Neutral Detent Arm Binding: The spring-loaded detent arm on the outside of the drum may be mechanically jammed or its roller bearing could be seized, preventing the star wheel from turning.
I don't slam any gears so I don't think any Shift fork is bent
I inspected the gears when rebuilt don't think the dogs are bad
The Shift drum maybe
The hope is the Neutral Detent part not coming out.
