Harley wheel front end options
lumbee
28715
Hey guys. I'm wanting to run a 21" HD wheel on my latest project and am looking for something that will fit between the stock lower legs. I'm thinking something 5-6" wide (bearing to bearing) is what I will need. I'm looking at these fore TC Bros:
http://www.tcbroschoppers.com/chrom...fxd-2000-03-sportster-2000-07-billet-hub.html
http://www.tcbroschoppers.com/chrom...fxdwg-1984-1999-fits-moto-iron-springers.html
Does anyone know if either of these will fit? I can handle the axle and spacers, I just need something that is narrow enough to fit between the lower legs.
The Sporty wheel is 4 7/8 wide and the Dyna wheel is 6.5" wide. Id say the sporty wheel should fit. Its just as easy to run a set of 35mm sporty forks in XS tripples as well. That way all you have to do make up the right spacers.
Thanks Rustie. I have extended forks in my XS trees, so I'm thinking its going to be easier (or at least cheaper) to just make this work. I can cut spacers and turn down an axle if I need to.
should just need to figure out what bearings match the ID of the wheel and OD of the XS axle. Then turn some spacers.
