Apexdc
It's never too late to have a happy childhood!
Ok, I reaching out for some good advice from the folks on this great forum. I've been lurking for a long time while I was figuring how my project and getting my issues organized.
Here's the tale. I grew up in Eastern New Mexico and bought an old XS650 flat track race from a high school buddy about a year and a half ago. It was raced in New Mexico, Texas and Colorado in the early seventies and raced at Pikes Peak in the 1976 Bicentennial event.
After I got it, I did a light cosmetic restoration, really more a deep cleaning as the paint and many pieces are original. I didn't get into the engine, but believed it to be sound.
Last May, I showed the bike at the Quail Lodge Motorcycle Gathering in Carmel, CA and lots of people loved the old school look of it.
Now, I am doing two things, getting it running and converting it from flat track mode to the way it was when it ran Pikes Peak. There, it used TT pipes and a front brake that I think was probably a Honda CB450 or Superhawk brake. There is a photo from 1976 showing the bike with the front brake.
My first issue is that the kickstarter had removed, as it was a race bike. As my goal is to ultimately get the bike on the street, I am trying to install a kickstarter. The engine, according to the S/N is a 1971 or XS1. I bought a kickstart mechanism on eBay and have it installed. However, the parts page illustration that I have shows one shaft with a thrust bearing and one without. The shaft came assembled with a ziptie holding a single washer. So, first question is do I need the thrust bearing or not?
Next, the clutch is obviously an early style with six plates. Should I try to upgrade to a newer basket, or just get six new plates from Mike's and keep the rest original or ???
As far as the TT pipes, I got a set with the bike that fit pretty well. they are 1.75" and about 37" long. I have some baffles that fit well for the street. Anything I should do differently there? I have seen some inserts from a couple of source that go up by the head, but wonder if I need something like that as I will be getting some restriction from the baffles.
I cleaned the Mikuni carbs and they look pretty decent. I have a Pamco ignition, but it is not fully installed yet.
Then, last, the alternator assembly was removed, but the shaft was not cut off. My plan is to just run the bike off the battery at first, until I get a feel for how much I may really end up riding it. If it is as much fun as I think it is going to be, I will want to get a charging system installed. Any suggestions on what I should use? I have to assume there were improvements over the life of the XS, but any parts will have to fit my '71 engine.
I would really appreciate any help and suggestions you can give. I think this bike is going to be a keeper and I'm loving bringing it back.
Thanks!!
Thanks!!
