boxbodybangin
when trying to learn how to adjust valve spacing, i noticed they seemed a little tight. not a whole lot of free play. from what i’ve researched, everyone says it’s better to run valves too lose than too tight. could this cause it not to run? i’ll keep the oil in mind. i’ll drain it at some point this weekend and post an update. if there are plastic bits, i assume that means i’m gonna have to replace the cam chain/chain guide?in my experience, given spark, fuel and air, these motors will run with grossly loose valves, broken chain guides, etc. I would look at the carbs now. make sure the fuel and air passages are clean. drain the oil, including the oil strainer and see if there are plastick bits in the strainer or the oil filter (that would be the chain guide). But the engine should still run with the guide lining gone. For the long term, put airfilters of some sort on
