HHB Complete CDI system ignition timing
jpdevol
Hacker of Frames,Wires and other things
XS650.com Supporter
26187
On your RH cam end is there another, empty, hole @ 12 O'clock?
XS1204
WA
No, just one hole.
I guess really I just need to know where the camshaft locating pin should be in relation to what cylinder is at TDC compression.
When I am at LH cylinder TDC compression stroke, the camshaft pin is facing down @ 6 o'clock
When I am at RH cylinder TDC compression stroke, the camshaft pin is facing up @ 12 o'clock
If this is ok, then we can put this to rest :) Thanks again!
jpdevol
XS650.com Supporter
26187
Well, I'm not remembering it that way. Hopefully someone else will come along and help:shrug:
Jim
XS650.com Supporter
Kansas City Mo.
No, just one hole.
'K... just looked in my big bore stash. With the timing hash on the sprocket straight up... like where you time the cam during assembly, the hole in the right side is also straight up. Now, look at the lobes on the right side... they're down... away from the rockers. In other words, the right cylinder is TDC on compression stroke.
That what you have?
jpdevol
XS650.com Supporter
26187
That what you have?
That's what was throwing me off:shrug:; the factory notch on the flange and the dowel pin are aligned
XS1204
WA
That what you have?
Excellent. Thanks for sharing. I am all good 😊
