Thank you for the validation!I know on my XS2, those breather hoses used to blow a lot of oil out of them, enough that it kept me busy with a rag to keep the undercarriage dry. You might recall I epoxied a couple small machine nuts inside the outlets to reduce the output. This only reduced it to the same size as the later model breathers that had those rubber restricted plugs in them.
So far this morning (re)set valves. (none were tight using .006 and .003") It still sounds very quiet.
Removed, cleaned, lubed, advance rod. Cleaned old grease off points cam
cleaned, lubed the wicks. Sanded, cleaned, set points, set timing with a timing light, checked both sides, then:
Timing good both at low RPM AND at full advance now.
Old factory manuals have you bending in the stops on the plate to limit advance but a Yamaha SB said to stop doing it, the bend is brittle and likely to snap off if bent later.
Off to the Badger Steam and Gas Show and swap meet. (For TX testing purposes only)
