Forks back on. A quick test ride, and fork action much improved but Oh man! I gotta change shocks. I have a set of progressives that I think will fit with just a bit of massaging to clear the chain guard, and making some bushings.
I've prolly showed this before but this scissors jack works for all years and is especially handy for the 70-73 that don't have the mouse trap front motor mount
the two notches I made in the bracket perfectly fit the nuts on the two mount bolts and hold the bike very securely.
It was just a garage sale find from an older car or truck.
When cranking up the jack NEVER go past the point where the rear tire touches the floor!
When fighting front wheel wobbles and bouncing don't ignore a possible issue with the REAR wheel. It's happened to me more than once where a rear wheel issue was felt, seen in the front.
, lady that T boned him said "I thought you were waving at me...)
Took me a while but finally realized my longer switch spring was creating a short from the can output to ground that was "buzzing" the can. I guess it started acting like a model T buzzer ignition coil, with rapid make and collapse of the coil circuit causing a field that energized the insulated from ground can. The Ole GG was the butt of the joke.
