CARB BRAKEDOWN.
Following carb-bank removal from the bike I boxed up the complete assembly. Loaded up my truck with the box, and the required tools to work on them at my workplace. The retail shop is currently so quiet renovating the carbs would be time well spent whilst getting paid! (Don't tell shop the owner..
Set up a work station in the shop. Clean white towel on the surface to catch minor spills; more importantly to catch small parts making a bid for freedom. 5 x Clean containers with lids at the ready for individual carb body parts (4 in picture).
JIS drivers and workshop literature at the ready. New fuel lines, clips and carbs kits at hand.
Lots of photos taken for reference, before starting, as these have complicated linkages which I have never dealt with before.; if it ain't a challenge it ain't intersting.
Initial look over showed the factory screws still in place with little evidence of damage; that encouraged me. First job was to remove all the rubber fuel supply tubes. None had securing clips attached, and some were barely connected to the spigots. Most were also suffering from cracking possibly caused by ethanol degredation?
Removal of the top 'dash pots' with the needles showed nothing suprising; all present and correct, clean inside and seems to be working. Just a quick wipe with cleaning solvent. Unlike our Mikuni XS650 carbs all parts were metal even the 'diaphrams'.
Flipp over the complete unit and time to remove the float bowls. As the bike had been standing for over 4 years I was expecting a lot of varnish and crap in there. To my suprise they were all realatively clean; just a little varnish residue. The floats moved freeley. I Checked float heights on each unit and they were widley different to one another; and none to book specification.
three of the gasket seals were intact, but the front left was damaged (The one that leaked badly).
the two visble jets were easily removed by wiggling the metal spring steel retaining piece. Same for the other bodies.
Most of the jets looked ok visually. But one did look totally clogged up with debris.
Two jets in each body have slotted heads leading you to apply a driver which did rotate them. However only the small center jet is screw fit. All others are push fit, and a right bastard to get out. Much fluid application and many sharp taps eventually moved the center ones. Eventually all were removed and cleaned. Unfortunately one jet through which the needle travels is bent. It looks like a PO had tried to force in into the body upsidedown; a new one to be sourced.
Finally each body has a tight fitting metal 'puck' that covers a chanel lower down in the body (blue circle).
One of the 'pucks' is missing in action (red circle)
The only source I can find for a set of 4 of these 'pucks' is from Randakks USA.
$15.36 seems fair enough; but $63.98 is the cheapest shipping offered!
I think I will try and obtain a secondhand body via eBay or FaceAche Fleamarket.
Unfortunately that halts the completeion of this job for now.
Ads.
