KEIHIN CARBS = The Rubic Cube of Carbs!
I recall the first rebuild of the BS34 Carbs on Taffy as being a bit scary for the novice that I was; but after doing them multiple times it became second nature to remove, rebuild, and re-install them blindfolded!
The KEIHIN carbs on Merlin are like bloody Rubic Cubes in comparison x 4!
First job was to remove all the rubber 'air' lines, none of which had securing clips.
Then the throttle linkage assembly which sychronises the two banks of carburetters.
Manual states '
First remove the nut to disconect the linkage' (Circled Red)
What nut
But of course there is NO NUT! Who would have thought that.
So I just go my own way and wing it; removing various split pins and nuts. Taking piccies to act as a reference for reassembly.
Suffice to say I did succeed in getting both the throttle linkage and choke linkage off the bodies.
Then you have to separate the plenum halves.
Getting the buggers apart was a fight to begin with
. Copious amounts of penetrating fluid, some heat and the use of an impact driver and JIS bits saved the day. All the screws were as tight as a Scotsmans Sporan; and took real effort to remove; some were bent along the threaded length, but luckily the carb body threads remained intact.
The five screws above allowed me to separate the two halves of the plenum, leaving each half with a pair of carbs attached.
Inside the plenum you can access the carb retaining bolts, which also secure the mesh 'blow back' screens.
Removal of the bolts and screen allow one pair of carbs to come away from the plenum; only for a load of small linkage pieces and springs to
fly off when the carb bodies were separated!!!
Didn't mention that in the bloody manual.
The other pair of carbs were separated taking far more caution so as not to lose any small pieces.
Each carb was then disassembled to component pieces. Bodies were scrubbed with degeaser and carb cleaner using various tooth brushes and rags. All 'brass' was removed and set aside. Bodies were then 'cooked' in the ultra-sonic bath until poached to perfection.
I did purchase a set of Jet Cleaning Wires from David Silver to aid the restoration as some original brass had to be reused.
Im sure I will use these again sometime.
All new brass and seals were installed together with new 'O' rings as required.
Reassembly took a while as a few days had passed and I had forgoten how they came apart. Applied logic won the day in the end, and all is back together now. New rubber hoses and securing clips have been used; and all of the cheesey headed screws replaced with stainless steel allen head bolts & washers (Should aid any future work on the carbs).
Next job is to get this lot back on the bike complete with new Ethanol friendly fuel lines.
More to come.
Ads.
