Ughh!It’s even worse when you are your own PO! Just sayin’.
Thanks for the kind words. It was a testing job to do, but so far quite satisfiying getting them back together.Adam you have done an admirable job with those carbs. Obviously someone worked on those carbs before and it appears got in quite a bit of a hurry. Very nice job!
Yep, I used to use your method I call the 'gravity' method.Nice Adam. But wow expensive.
Not looking forward to that myself, empty coffers.
I always hung my in a baggie with oil in it and a rubber band wrapped around it to seal.
Clip it to the wall and let it do it's thing. Works well.![]()
A fair shout but I would like to keep this ride as original as possible.I see a single carb conversion kit in your future.
OIL DEM CABLES!
Along with the carb rebuild I though it prudent to replace all the control cables.
Some of the exisiting ones are quite worn / frayed or just stiff. More money to the coffers of David Silver Spares!
Clutch / 2 x Throttle and a choke cables came to £107.49
Two throttle cables shown
View attachment 333674View attachment 333675
Anyhoo before installation I like to lube the cables, even if they have PTFE liners.
Some people try and squirt oil down the actual cable housing directly into the hole; and waste a lot of oil.
Best to dribble oil onto the wire itself and let it seep into the housing. An occasional push / pull on the cable draws the oil down further.
I attack the job in this way from both ends.; Its much quicker than using the 'gravity' method.
View attachment 333677View attachment 333678
Onwards and upwards,
Ads.
Hi @jaybar6Hey, Adamc: Whats happening with that wizard, Merlin?
Those gold wings are more complected than I original thought!Hi @jaybar6
New seal just arrived today for the plenum.
I will start dismanteling the carbs again tomorrow at work (Owner is away)......
I cant belive the whole assembly has to be pulled apart to install this bit of rubber!
I have also removed the ABS system from The Brat (R1200GS); need to bleed the conventional system it has now and rebody the tupperware.
Then another look into the intermitent heavy misfire on Taffy too.
Updates to follow soon.
Ads.
Correct on all three counts.Those gold wings are more complected than I original thought!
And the bmw' s - do they all have this ABS fault with the flashing light or is youtube just showing me many videos on the algorithm?
Now Taffy is a mystery, you seem to have attended all aspects of a new build and yet...
I can sympathize with you it is very frustrating when there is fault on the bike.Correct on all three counts.
Very frustrating bike season for me I can tell you.![]()
I had the bagger version of this classic which I was in the middle of converting to what you have when I donated her to charity. Worst discission of my life. I envy you. The one I had was a great bike and I miss her dearly. Fix her up and take good care of her and she will take good care of you.MERLIN a story about a 1975/6 Honda GL1000
This bike came into my life via a late night drunken bid on eBay!
I regularly flirt around with eBay, buying and selling vinyl records mostly (my other weakness). However one Sunday evening after dinner and too much wine Mrs C wanted to watch a chick flick, so I fired up the Mac and started trawling through bike adverts as you do. A bike I had always wanted from way back when popped up; it was well photographed but had a poor description. It looked good and as only one bidder was shown with just hours to go I put in a cheeky bid, and went to bed. The next morning I get a notification that I had won the bike and must now pay!
Bugger me with a rusty breaker bar! what the hell will I tell Mrs C now? I made a brave decision to tell her nothing at all; so that sanity and my life would continue in peaceful bliss. Wifey was going away to Spain with her sister in two weeks so I would keep quiet until she returned.
So this is the bike I won:
I arranged cash on collection with the vendor; and sent my delivery team to Worcestershire to collect it.
The vendor sent me a text when the boys had loaded and the cash changed hands. He asked by text for my address to send the receipt and DVLA documents (change of ownership) to. I frantically text back saying to give the lot to the boys as I had not told my wife yet of the purchase; Whew that was a close call. The boys took the bike straight to my lockup / workshop; and I was eager to get there from work to see it. At 4.00pm the work phone rings and Mrs C is in Cardiff shopping for her imminent holiday; she wants me to meet her in a restaurant in town and take her home after dinner. Bugger foiled again. Dinner was good but to be honest I faked interest in any conversation as I had something else on my mind; including a guilty pleasure! The bike would have to wait until the next day.
Up early and straight out the door to the workshop. Open up the lockup and I'm pleased to see the bike for the first time; it looks very good, not immaculate, but very good indeed.
First impressions are great. I was told the bike was a 'runner' having covered only 400 miles in the past 4 years with its second UK owner. He also told me of a poor idle and loud whine from the tachometer. A quick check of vital fluids and visuals for anything obvious and time for a startup. Key in dash lights show all good; check neutral, and turn the key.... A click from the starter engaging ....No cranking however.
Still pleased I pushed the heavy bike back into the shop and locked everything up; got to get to work. This will have to wait for the weekend.
