So I have some updates and curious results which have me a little stumped.
Running a vm36 single carb
25pj
200mj
P6nj
New 3.3 float needle
Floats 18mm
Quick question - I can’t find a diagram anywhere that shows 2 paper washer under the float needle. One under the needle, then the plate, then another under the plate between the carb body. I replaced the washers with new ones, too, which really changed the float height so I reset to 18mm. That’s how mine came so keeping it with 2.
Tried a 180mj and got popping and drop in throttle after holding it open so went a little richer, especially after dropping from the p8 to p6.
What’s got me stumped is initially my left cylinder ran steady and my right fired loping like a harley. Figured maybe it was the longer run on the manifold. After having idle issues I cleaned the plugs and swapped sides. Right side steady now and left wasn’t firing. Put in new plugs and right still firing steady and left intermittent. Header only gets warm and right is screaming hot so tuning the carb is impossible. Battery is 12.5v at startup so should be good. Tested coil - primary 4.2, secondary was 25. So not the coil. Can’t figure out why it was running stumbling on one side and now the other side. Doesn’t seem to be electrical
