Paleomechanic
Hi guys ,
Well, things are coming along nicely , just two hang ups in the re wire . For those not following the “adventure “, I’m using ones of Mike’s harness
So, everything works except horn and signals
Horn first . My Observations! I have power though the horn all the time , meaning that without the button depressed, I have power on the brown going in, and power in the pink going out of the horn, button use does nothing . Bad switch ground perhaps?
Signals . Blows main fuse when install 3 pin relay unit . Oddly, I tossed on an LED one as well “ just to see”. Doesn’t blow fuse , just hums when I select left or right . Lights do not flash
Lights hooked up correctly, and independent verification on each light done , so no shorts to ground
Question ?? Is there a particular aftermarket flasher relay I need ? Or, can someone verify which colour wire goes to which prong ( ie to which prong marking ) just in case I’ve got a dead short when I’m plugging in
All the best guys and thanks in advance
Nick
Nick
