How-To: Rebuild XS650 Forks / Install Lowering Kit
The 35mm forks off bikes i have had. 79SF, 80SG, 81SH have all got the same as your 35mm type. I was reading recently how a lot of Japanese bikes were shipped to NZ and Aus, also with the import mob making money from the XS650 revival we have been swamped with them
This was a HUGE help! I looked at the diagrams, read this article . . . and still assembled in the wrong order! Checking back, I realized my mistake and re-assembled correctly!
Great article for reference!
Hello, I have lowered my forks by making a 1 inch spacer as described here for my 73 tx650. I didn’t chop the springs thinking the extra stiffness would be handy. When hitting a bump it’s bouncing back firm and when fully extended it makes a knock. Would this be because I need to chop the springs or some other assembly or oil level problem? I have added oil to the specs in the manual.
Thanks for any help!
A top out spring would definitely prevent the knock you experience. More rebound damping would also help. Shortening a spring actually does two things, increases the spring rate, and decreases the pre-load.
I would try with thicker (higher viscosity) oil first. And maybe a shorter spring preload spacer.
When messing around with suspension, you first need to get unladen and laden sag into the ballpark, then deal with the damping dynamics later. There are several good books on the subject, and it is interesting reading. Racetech and Wilbers are two suspension suppliers that also sell books. The Ohlins website also has some useful info. And surely others as well.
Thanks arcticXS. Would you recommend cutting the spacer down 1 inch? I’m using 15w in the forks so try some 30w if chopping the spacer doesn’t work. Thanks for the advice I’ll read up when I get a chance as I’d love to have the handling as good as possible!
Have you tried to measure laden sag? In other words how much the forks compress from fully extended, when you sit on the bike in a normal riding position, while a buddy is holding the bike upright.
I would aim for around 35 mm of laden sag. The length of the spacer will influence the sag directly. Cut off 10 mm, and you get 10 mm more sag. If you feel that the fork is too "soft" in compression after setting the sag, you could try to raise the oil level.
Awesome thanks for your help I’ll check the laden sag and go from there!
and have at it .....
HI 5T. I only quoted the above because I was looking for some advice, starting with you. Please, all others chime in!
First of all, I have the 72 and I don't have 1/2 the parts inside my shocks. I got every thing apart, but I can't figure how to get the chrome dust covers off without wrecking them. My manuals consist of an XS-1 and 1B and a 72 suppliment. Nothing about the 72 forks.
I'll take some picts of my parts while I wait for the wisdom to flow in.
I'm afraid I can't be of much help on those chrome dust covers. I've never worked on forks with them before. I'm sure Mailman has info on them. Maybe he'll chime in soon.
I appreciate it, though, thanks. I'm pretty sure the 71's have the same chrome cover, but on steel lower tubes. I actually have an XS-1B book, but it doesn't mention how to remove them. Oh, here are some picts for the archives.
20200323_201115_resized.jpg 20200323_201123_resized.jpg 20200323_201317_resized.jpg 20200323_201408_resized.jpg 20200323_201501_resized.jpg
I only need the 8mm allen wrench, No special tools.
Haha! I just PM’d you with the answer on how to remove the chrome caps, I didn’t see this post earlier, so I will just add it here.
The chrome covers are simply a slip on fit. They get stuck over time, grab firmly and twist and pull straight up, maybe shoot a little WD-40 in there if necessary. The underlying rubber dust cap has a lip that snaps into a groove around the top of the fork lower legs, when they are in place and you slide the chrome cover over them, it sort of locks everything in place.
I really appreciate your wiseness. No, really. I didn't want to screw it up. Those chrome covers add a lot to the look. Thanks. I owe you big time. They will be off in the AM.
Yahooooooooo!
Hugh, thanks for the how-to. While I'm not lowering my xs other than the billet top clamp your how-to allowed me to take on replacing the fork seals. Something I haven't done before. What a Pain in the butt getting the old seals out. Other than that all went well.
For the late models, I just took a 2 inch long bolt with a 17MM head and nut and welded the nut onto the bolt. Basically making a dumbell with 17mm heads. I figured this would be easier than wrecking a perfectly good socket.
Thanks again.
I don’t have a welder, so did the same thing with an M10x20 using two nuts, a lock washer, and red lock-tite. Worked like a charm!
Guys, on the early model forks. If you remove the spacer, do you need to place it somewhere else in the array to make up for it "ca-chunking" if fully extended? If not, that's a hella convenient way to lower without having the forks protruding above the top tree (on an SR500....ooopsie!)
Ohhh, you need to place the hand made 2" spacer on the damper rod . So removing the 1.5" spacer is like giving yourself a 1/2" of spring pre-load...Am I correct?
