Hugh & Co., I got the 2" spacers. Thanks. (2 holes, no set screw) . I have an SR500 and my forks are the early type with the recessed cap nut 17mm hex (used a timing wheel puller screw top, fit perfectly and you use a crescent wrench on the part that sticks proud). I also have the stock 2" spacer on top. However, when I look down the tube, I dont appear to have the 2 flat sided damper rod that requires the 17mm socket mod. Could I have a combo of the later damper that requires the inserting of a Allen wrench end along with cracking the Allen wrench on the opposite side? This is odd because I have the top steel spacer. Is this an SR500 set up? I don't believe the guy I bought this from ever had these forks apart. Just looking to get these forks sorted tonight. Thanks.
