I hit the Trifecta!
Downeaster
Everything in XS
Downeast Maine
When you have a light problem on a trailer, there are three probabilities:
1. Bad bulb
2. Bad ground
3. Bad wiring/connection.
Got a road trip scheduled tomorrow and by way of preparation drug the little trailer out and checked it over. No Joy on the ditch side tail light.
First check - bad bulb. Broken filament. 'K, easy fix, replace the bulb. No joy.
Second check - Pull the fixture off the mount and clean up the mounting surfaces to make sure I have a good ground. Visual check indicated it was sorely needed. No change. Huh.
Third check - I have one of those nifty plugs with the little indicator lights and it showed power at the plug, multimeter showed nada at the bullet connectors on the light end. Wire was pretty crusty, brittle, cracked insulation. No problem, I have a stash, I'll pull a new pair through the conduit by taping it to the old pair. Wrong, buffalo breath, that wire was NOT coming out of the conduit. Which pretty much pointed to that as the problem. Strung some new wire on the outside and crimped on some new heat-shrink connectors (twice, after discovering a miss-crimp) and voila! let there be light!
Now I just need to free up the tongue jack (or more likely hack it off and get a new one), check the tire pressures and swipe the spare off the big trailer.
I have several watercraft and the small 8' trailer I use for the bikes and I swear every year I have something I have to do to one of them.
good luck on the road trip!
A while back I bought a magnetic lighting kit to use on a car being towed with a tow bar. If I ever finish my 5' x 7' trailer I'll use it on that and store the light kit inside out of the weather when the trailer is not in use, about 99.7 percent of the time.
I have one of those kits too. I’ve used it on borrowed trailers several times. Like you said, good for towing a car too.
