eldiablo1211
XS650 New Member
This may have been covered before but I couldn't find anything regarding a Honda shadow voltage regulator on the xs, I'm finally in the process of getting to the wiring, and don't quite know if this will work and deff don't want to mess something up.. I have been browsing the forum for a few years now, and a lot of you guys know your xs's like the back of your hands!! If I have to I will buy the correct regulator! I just had this one laying around and figured I may be able to make it work,..
Any help would be appreciated!!!
I'd like to just get the bike running then work on other circuits later if possible.
I hand drew a wiring diagram if it needs fixing or can be slimmed down on wires please point me in the right direction
My questions are do The reds from the regulator go directly to the battery or to the key switch
I have the greens to the green on the stator, the 3 yellows to the 3 whites on the stator, what gets plugged into the yellow from the stator and does the black from the stator go to a frame ground? Or ground on battery Or should I move black to one of the greens.
Will this even work or should I just opt to buy the correct regulator?
Thank you all in advance
