Been chasing an issue with my '75 XS where when coming to a stop the idles drops to lower than 1k. Usually the bike then stalls. If it doesn't stall, or I blip the throttle to keep the revs up, the idle will slowly rise back up to where I have it set at around 1800 rpm (set high trying to compensate for the drop when stopping). Initially I thought it was a float height issue. So I adjusted them but accidentally went the wrong way and lowered the fuel level. Naturally issue persisted. Took carbs off again to double check float height and discovered my mistake. Floats are set to 24mm on either side and on both carbs. Took the bike out and issue is still there. Thought I might have a dirty pilot jet but seems odd that it idles fine just sitting if the jet is indeed dirty. Any ideas as to what I might be missing or could check next?
Carbs are stock. Carbs air/fuel mixture needle is set to half a turn out. Using Uni pod filters and inline fuel filters. Just ask if further information would be helpful.
Thanks
Thanks
