Idle drops significantly/bike stalls when stopping
Finally have some new results to share regarding this.
Got a new regulator that was faulty so that had me chasing my tail for a bit. Got another one and installed it. Battery level before starting with new regulator: 13.3. Started the bike and at idle (1800 rpm) voltage at battery read 15. Switched on headlight and voltage at battery rose to 15.5 at which point I shut the bike off. I then proceeded to go through some of the steps in the charging diag post in the tech section. Did the crankcase slap test with key on and that worked. Measured the voltage at the brown wire feeding the regulator from the key and that read between 0.05 and 0.25 volts below battery voltage. Green wire coming from regulator to positive brush with battery at 13.3, read 12.5. This is where I stopped because my system is overcharging rather than not charging. As I write this though, I realize I might as well do the other checks and make sure my rotor and stator wires are good.
I then went a step further and unplugged everything except the ignition wire. Started the bike and at idle was still in the 14.9 - 15 volt range. Wanted to rule out some other circuit possibly drawing power and causing issues.
I am confident my battery, regulator, and rectifier are good since the regulator and rectifier are new and my battery seems healthy. However, all the signs say my regulator is bad. Any ideas what might cause over charging if the regulator is good? I can try hooking the brown wire straight to the battery so the regulator is reading off the battery but I get so little drop in that wire that it didn't seem necessary. I can also bypass the whole regulator and see if the issue with stalling continues but I fear I will cook my Boyer ignition and/or blow lights (had that happen in the past when I connected the regulator incorrectly). Theoretically they are protected by fuses based on my wire diagram but my knowledge of electricity isn't great so I don't want to just hope I am correct.
That says your regulator is sending power to energize the rotor. The regulators job is to cut that power when the alternator output gets to about 14V.
If you're going up into the 15V plus range, it means the regulator is not cutting that power.
Unless your bike is miswired and sending batt power out on the green wire, you've got another bad regulator.
Where did you get the regulator from? Show us the web page where you bought it?
Did you try as ggGary suggested and run the bike on battery only(fully charged battery, physically disconnected regulator/rectifier)? That seems like a surefire way to ensure that it’s not a fuel issue, and it will also tell you that the regulator/charging is bad forsure if everything runs great(for the limited time that the battery is charged, it will discharge of course), but it does also sound like there is a regulator issue causing overcharging.
I just wonder why the system voltage would go UP when turning on the headlight, that seems odd to me.
With regard to fuses protecting things, the fuse protects from excess current(amps) but a fuse will not protect from excess voltage(electromotive force)
An analogy of voltage is like pressure in a hose.
The amps would be the amount of flow volume(like how quickly you can fill a bucket with water. Increased pressure usually helps, but if there is a high restriction, it limits flow)
Ohms is like the restriction level(think nozzle or orifice)
Charge the battery fully unplug the VR take it out and ride (mebby leave the headlight off)
Does that change your idle issue?
You are aware of early and late charging circuit brush differences?
Early
Late
Early the VR controls +12 brush
Late the VR controls ground to the other brush.
You can't use a late circuit on early brushes unless you do the Nylon screw mod.
The regulators I have been getting are Standard VR115 through O'Reilly Auto Parts. The first one I got wasn't sending any signal (through the green wire) to the stator. This one sends signal but sounds like it isn't turning it off. Can I check whether the green wire is turning on and off or is it too fast switching to actually test?
I like the idea of riding the bike on just the battery. That would hopefully reveal what area the problem is in.
I do find it odd, like MikeDeepXS, that voltage goes up when load is added. And also that at idle it is putting out so many voltage without revving the engine. Seems like it should idle around 12.8V and when revved show numbers between 13.5V and 14.5V. Don't understand how I am getting 15V at idle.
Check wires, grounds, switches, and connections. A bad connection somewhere can fool the voltage regulator into thinking the voltage is lower than what the battery is actually seeing. where do you have your voltmeter tied in? check that the ground brush is NOT grounded when the voltage regulator is unplugged.
Voltmeter is tied in off the ignition switch. Not sure I understand checking the ground brush not being grounded. It is grounded through a ground wire so it is always grounded regardless of whether the regulator is plugged in or not. If that is incorrect, how should it be wired? I have the earlier system that shuts on and off the voltage through the green wire and not the newer version that shuts on and off the ground from the ground brush.
Been chasing an issue with my '75 XS where when coming to a stop the idles drops to lower than 1k. Usually the bike then stalls. If it doesn't stall, or I blip the throttle to keep the revs up, the idle will slowly rise back up to where I have it set at around 1800 rpm (set high trying to compensate for the drop when stopping). Initially I thought it was a float height issue. So I adjusted them but accidentally went the wrong way and lowered the fuel level. Naturally issue persisted. Took carbs off again to double check float height and discovered my mistake. Floats are set to 24mm on either side and on both carbs. Took the bike out and issue is still there. Thought I might have a dirty pilot jet but seems odd that it idles fine just sitting if the jet is indeed dirty. Any ideas as to what I might be missing or could check next?
Carbs are stock. Carbs air/fuel mixture needle is set to half a turn out. Using Uni pod filters and inline fuel filters. Just ask if further information would be helpful.
Thanks
You might want to pull the tank and make sure your ignition wires are fully seated into the ignition coils. it sounds like you might be losing spark in one your cylinders. I seen it before.
Had to put this project on hold for a bit this summer. Update on where I am at now.
Unhooked the charging system and ran the bike on battery only. First stop sign I stopped at, bike idle drops to right around 1K rpm and then stalls. So it seems my run issue is fuel related. I cleaned the carbs and jets, everything looks good. Reassembled, test rode, and issue persists. I reread some of the comments here and one was talking about this being a symptom of float level being too high. Based on the carb guide I have my float level set to 24mm. I can double check where they are at and set them lower. Maybe 25mm or should I go more? Lastly, I have pod filters and my mixture screws are set to 1/2 a turn out. The carb guide says start with them 0.75 turns out. It seems like with more air flow from the pod filters I would expect to run with the mixture needle richer rather than leaner. Is that a correct assumption? My thinking being maybe I am running too lean. Will have to check my plugs but I am sure they will be black from the bike mostly only idling since I haven't taken it for a proper ride all season due to this issue.
What type pod filters? The pleated K&N style filters can partially block the ports in the carburettor inlet.
Real K&Ns are usually ok because they don't have a stepped flange on the filter ID, and it's the step that does the blocking. Some K&N-style clones do have a step, so it is a good idea to take a look at this.
Thanks
Clutch drag ...that's a maybe... electronic ignition doesn't like voltage...that's a maybe. Also you say that you are using UNIPOD free flow air filers...another maybe. any air flow which is greater (or smaller) than the air flow with the original filters upsets the set up between the diaphragm spring and the slide itself and the throttle slide assembly can open either too wide or not enough when the throttle butterfly is opened. This is a common issue with CV carbs and why lots of people building specials use slide carbs. The CV carb is a very good carb but if you start changing the inlet air resistance you ned to change the springs.
Not really on a very lightly modified engine. Granted, changing the inlet configuration will have some effect, but mostly on mixture i.e. why jetting, needle position, et al is often modified for pods. But the CV carb really answers the vacuum signal from the engine and this is far stronger and more consistent than any inlet restriction mod. So I don't think the pods/slide springs are the problem. Don't know where you could reliability source slightly different slide springs in any case?
I am accustomed to SU carbs which operate on exactly to same CV principle and one of the things you should do when changing the air filter to a K&N is fit a RED spring to compensate.....and this works very very well. Sourcing slide springs? just find a mikuni specialist.
Not familiar with the SU world, but I will take your word for it. I don't think there are any optional springs listed for a BS38 or BS34. Most mods to change slide behavior on this carb might be focused on the vacuum lift port(s), assuming you need a change.
But in any case, that is not the OP's problem; and there are many people on this forum running UNI pods successfully without a need for spring swap or drilling the vacuum ports in the slides.
