The XS kick start goes through the clutch and primary drive, so all starter motor drive components can be removed, should you want that.
Just be aware that the XS kickstart is a bit awkward, since it requires the gearbox to be in neutral and the clutch engaged. So if you stall the engine in 1st or 2nd gear, for example, you will first need to select neutral, kick start it, then pull the clutch and select 1st gear again.
Other bikes, like Yamaha RD models, have a kickstarter that can be used when any gear is selected, you just need to.pull the clutch first. A so-called primary kickstarter, much more convenient than the XS setup
