That is VERY simple to check. Disconnect the capacitor/ condenser, but leave points connected. And coils connected both to power (brown) and to points (Grey/orange) Then turn engine so the points close. Connect voltmeter + lead to coil negative side (grey or orange, depending on what side you're checking. Voltmeter - lead to any good ground on engine, i.e cylinder head fin. With ignition and kill switch on, you should see less than 1-2 V . To check the supply voltage to coil, move the + lead to the coil positive side, with everything still connected. Now you should see very close to battery voltage. If not, you have one or more poor connections.
Note that it is not very useful to disconnect the brown wire and check the voltage with no load on the circuit. The coils draw around 3 amps, so any resistance in the supply to coils will reduce the available voltage across the coils significantly.
