I just re-assembled the shaft / counter weights, and etc. on my XS2 after cleanup and lube. I'm thinking that I read that the timing wouldn't change by doing this. I understand that the valve timing would not change, but I'm a little confused when I try to figure out why the ignition timing didn't change. The only thing I can see that couples the ignition timing to the valve timing are the notches in the notched disk. Is that correct? I just have a hard time understanding how that could be accurate enough. Maybe my brain just needs a reset. LOL
