After reading the Smedspeed site's section on modified engines—particularly ignition timing advance—I started thinking about their advice. The recommendation is to use more advance at low rpm, less full advance, and a slower ramp to 3500 rpm for performance builds (https://www.smedspeed.co.uk/tech.html). While reducing advance is often discussed (https://www.xs650.com/threads/xs650-ignition-timing-revisited-are-we-too-advanced.45197/), extending the ramp isn't covered as much. Smedspeed suggests bending spring posts, which seems drastic. Are there other ways to achieve this, like using stiffer springs or modifying the existing ones?
For reference: the stock advance curve
The Smedspeed advised:
I also tried mapping the advance curve on my bike using the tach reading and a rudimentary degree gauge below.
I have the timing set at idle at the lower range of the spec. It seems that my springs (10 year old from Mike’s XS) are a bit weak as the full advance is reached by 2500rpm.
Here are all the maps super imposed.
