Yeah it was futsy, IIRC the magnets tended to move it a bit when setting in place.Getting the rotor lined up perfectly
It's fixed. Bringing the module closer to the coil didn't hurt. After the carbs were gone thru and cleaned again it fired right up. Says in the directions these units can be mounted anywhere so I did. Seems rather exposed, so I asked the question about weathering. I did have the doors shut and lights off in the garage checking for spark. Yes it takes a brisk kick to start but starts first kick. It's two separate circuits but I still have a on/off toggle to the fuse box for all my lights. After running, turn everything else on. Forgot to add, no battery. Sparx capacitor only.Heres my quick thoughts. You may be trying to fix a problem that dosent exst. CDI ignitions need to spin fast to generate a good spark, if kicking you must be agressive and if using electric the motor it must turn over briskly.
Lastly CDI sparks are hard to see especially in bright daylight. I once installed a CDI and spent some time trying to fix a no spark problem pushed the bike into the shade of the shed and could see the spark that was there all the time.
The ignition switch only disconnects the "other" electric loads from the battery. The charging system output is always connected to the battery through the regulator. It is in the stock system also.
Theoretically even with the ignition switch off, rolling down a hill in gear (engine turning) a PMA alternator would still charge the battery.
So with an independant kill switch you can shut off the main switch, leave the engine running and charge the battery with everything else unpowered. "sneak out mode" If everyone in the neighborhood is deaf.
I am hooking up a vape system on my 80 xs650. If I want to use the original kill switch do I plug the black wire up to the R/W going to the old coil OR the R/W at the fuse box?
https://www.xs650.com/threads/headlight-relay.22655/#post-220614New Vape system works!
Now my front headlight does not come on because there was a yellow wire that came from the old alternator that is disconnected. When I hooked the yellow wire up to the Battery, the light worked but for some reason then my ignition switch wouldn't work. Canceling each other out.
Taillight and turn signals all work fine.
Iv looked at numerous diagrams..
Should I be linking the yellow wire somewhere else?
Is there room for an honest product review opinion?
