Gonna use the forbidden P wordI’ll double check with a straight edge but they look flat to the eye
Permatex
Does jbm say this on their website? I see where it says designed to not need the metal shrouds but I don’t see where it says about not needing gasketsJBM states their boots don’t need the gaskets. But they still sell them anyways. Go figure.
I got the red kind brand new tube just in caseGonna use the forbidden P word
Permatex
Gary, you don't understand. That excess around the inside diameter is to help atomize the mixture. Jeesh!!!
I read that also but it doesn’t say about gaskets?
Ahhh I see thank youI stand corrected. I mis-read your question. Here is another clip from their site that may further clarify.
That was my next route if I can’t get this leak to go awayI had this issue with my '79. Even worse after i swapped out the original carbs for a pair of VM34s with v stacks. Picked up the billet aluminum manifolds from tcbros and the added length and rigidity plus thick boots has resolved it for me - so far 2.5 years as a daily without a recurrence.
Sure looks like it is overtightened and causing an arch in that area.
80 in. lbs. is less than 7 ft. lbs. . That is just a little more than finger tight.
