Ever think about a XS trike?
I have...
I have...
I have...
The power feed on my 10" Atlas hasn't worked since I put it back together from the pile of boxes it came in.... no gears for it. Periodically I keep an eye out on Ebay for reasonably priced ones, but they were always north of a hundred bucks, so I never pulled the trigger on 'em. About 10 yrs now of hand feeding.
Was down in the basement yesterday cleaning a section out for yet another remodel job. In this corner I found a small, unmarked and beat to crap cardboard box. 3 guesses as to what was in it? Yep... two... count 'em, 2 full sets of power drive gears.Holy crap! Christmas came early.
In my excitement, I didn't get a pic of the box, but here's a set I put in a drawer in the lathe table and a set I cleaned up and stuck on the Atlas.
More huntin' around turned up the thread chart. Cleaned it up and installed. The latch for the gear cover was another missing piece that was in the box. Cleaned up and installed that also.
And since the poor ol' thing has taken to chattering to beat the band, I took it back apart from the saddle up... I had to, yano?When I initially put it together, I pained the saddle, crossfeed etc yellow. It was late at night and I was out of the grey I used on the rest of the lathe. Never liked the color and regretted not waiting
Sooo... I had to repaint 'em. It's in my blood. Seems I can't fix anything without it involving paint.
Obviously everything was cleaned prior. Greased everything and got it all back together except for the apron. The half nuts are shot, big time. So the apron will stay off for a bit. Found a set of brass ones at Amazon.
Supposed to be here Sat. 69 bucks sounds kinda steep, but the Ebay pirates want more than that for a used original set. The original were cast out of Zamac of all things. For those that don't know, our BS carbs are cast from Zamac. It's soft and was never intended to work in high friction settings... like nuts. File that under what the fuck were they thinking... Anyway, the brass ones will likely outlive me. Soon as they get here, we'll find out if I actually have a power feed that actually feeds.
Forgot to mention, all the gibs were loose as hell, so after I get 'em all adjusted, that should clear up the chatter. You know... the reason I did this in the first place.![]()
A TIG welder is one of those "where have you been all my life" tools. A bit of a learning curve, but well worth the effort.My turn...had more fun in the shop the other night than I have had in a long time. The shop finally got a TIG welder! Now hard at work developing the appropriate knowledge base and skillset!
If you've done gas....I have done plenty of stick, gas (oxyacetylene) and MIG welding over the years, so the basic welding skills are there. The goal though is those picture-perfect TIG welds!
It appears to be easier said than done! I agree on the principle, though. We (son and I) are working on getting the settings right for the material at hand. There are plenty of tutorials out there, so we'll get there with trial and error.If you've done gas....
One of the best tips I ever got was from an old welder's off the cuff comment. As he sipped his coffee, he said "you can gas weld, you can TIG weld... it's the same damn thing!"
He's right. Make a puddle, add filler. Heat is heat. How that heat is made is immaterial.... it's heat.
Agree. Saying it and doing it are two completely things. Just keep that in mind as you practice. Another thing I'd suggest is regular practice. It's not like riding a bike. I went several years without using my TIG once (or twiceIt appears to be easier said than done! I agree on the principle, though. We (son and I) are working on getting the settings right for the material at hand. There are plenty of tutorials out there, so we'll get there with trial and error.
That looks top notch!Atlas Shrugged.
No joy on the half nuts. Supposed to be here today and all tracking sez is "shipping label created."
So I stuck the apron back on sans the half nuts, so it was usable the old fashioned way... hand fed.
The compound slide knob has never had the little pins you turn it with. Thought maybe the discovery of the lost cardboard box would yield them, but no... still MIA. So I put it back together long enough to make a set. The originals were zamac, just like a lot of cast parts on these ol' lathes. Not having any zamac, I used brass. Made 'em to a light interference fit, then hedged my bets and added a dab of J B Weld to stick 'em in place. Looks right spiffy methinks.
Oh, forgot to mention...the TIG welder purchase was complimented by a plasma-cutter purchase; another game-changing machine. Cut some steel plate that I had to build a mobile steel-topped welding table... pictures to follow ('cuz y'all love pics, right?).My turn...had more fun in the shop the other night than I have had in a long time. The shop finally got a TIG welder! Now hard at work developing the appropriate knowledge base and skillset!
A friend (who is an expert welder) dropped by last night and coincidentally made the same comment of gas welding compared to TIG. Unfortunately for me, my gas welding skills suck.If you've done gas....
