Is it my turn? Anything to do with lathes, mills and other shop tools
This old indexer? Thing came to me in a lot of stuff I recently purchased. It has 24 positions. I image it could be used for tool grinding. Does anybody else have any ideas what it’s for? Is the there any value in it?
Thanks
Stephen
You can use that for all sortsa stuff. Milling wrench flats on shafts, drilling and tapping shafts, milling hexes for 6-point wrenches.
Keeeeeep iiiiiiit.
Edit: milling multiple keyslots...
We have a 4th axis in one of our CNC mills, it never has a day off it seems.
Might have to put in some OT and get me one of those.
Don't know why I need one, but I might use it in 20 years. So therefore I need one.
I would need a larger garage/shop to get something like that. I had to put the boring bar between the mill, compressor and garage door to not lose floor space while having room to use it.
Here is my logan 200 , I would be lost without it ... I do regular lathe turning plus starting to do some milling with it .... here is a project I worked on last yr building a prop shaft bearing support for honda outboard
Nice... I feel the same way about my Logan 820. Is that an offset drilling fixture fitted to the tool post, powered by a drill (or something similar)? If so, I like it. I built a similar device, including an arm to offset the toolpost from is normal mount on the compound, in order to be able to drill into the perimeter of a workpiece in the chuck.
That is exactly what it is .... I built 2 of them , a light duty one that I can run with a 3/8 .... and a heavy one that I can do some light milling with , cut a key way in shaft ECT.
I purchased a lock to hold chuck and my big gear with teeth marked at all the popular patterns for accurate hole spacing.
Will post more pics of some of my projects at a later date.
I prefer to make as opposed to buy, not to save money but because I enjoy the challenge
To change the subject a little my girlfriend brought me home a present from her work. A very small and very cute tool box. :)
Inspired by this post I asked for one and lo and behold, my prayers were answered.
I think the cat is jealous he doesn't have his own toolbox.
Does anyone here have experience using a pneumatic needle scaler? Are they pretty effective at removing fairly heavy surface rust and if they work well, do they beat up the base metal badly? I’m thinking about getting one to use on the beetle project.
Yup... have used one to clean a very scaly truck chassis. In my experience, very effective at removing surface scale yet doesn't damage the underlying surface too badly. You would not use it on thin material, but suitable for heavier chassis parts.
