Its actually round tube pieces welded together.
No they're not. It chatters way too much turning metal down.always nice to add a personal touch to machines!
I dont know about your experience with brazed on carbide tooling (the red one) but i dont find them ideal on small non rigid machines.
I found with brazed carbide you have to grind them just like a HSS blank. Small low powered machines do better with sharp tooling, it's why insert tooling is hit or miss on them. Out of the box brazed tooling kinda sucks. With a proper grind it works well, it also helps to buy better quality with the right grade of carbide for the job. But for my 10" atlas for heavy cuts I do get better results with the right grind on HSS blanks.always nice to add a personal touch to machines!
and for stainless?For aluminum I always try for HSS. Carbide (unless specifically made for aluminum and has a high polish and a razor sharp edge) has a micro radius on the edge. It works essentially by pushing the material off the workpiece.
Take a carbide endmill and drag it across the palm of your hand as hard as you can. No problem.
Try that with a HSS endmill and let us know how many stitches you need.
Point is, carbide is best for harder materials like steel, whereas HSS is best fir softer materials like plastic and aluminum.
I'm with Bjorn, the carbide endmills we have at work will slice you open if you look at them funny. If they are tight going into the holder or coming out you better wear a glove, or you'll need a bandage. The ones for plastic are probably the worst.For aluminum I always try for HSS. Carbide (unless specifically made for aluminum and has a high polish and a razor sharp edge) has a micro radius on the edge. It works essentially by pushing the material off the workpiece.
and for stainless?
asking for a friend. Doing this with sintered carbide but it's mainly a power through, pretty blue chips thing.
