Thank you. This HF stand has bearing cones and I was able to secure the unit solidly in 1 lateral position against upright. The HF has little roller bearings that the axle can roll on. This seemed crude as the shaft is not a machined or high quality bar stock. I secured the axle shaft cone against the upright so that the hub was rolling on the wheel bearings. Dial indicator gives me L/R .006-.008 except at the weld and .008-.012 up and down except at the weld. I will leave it sit and revisit another time. Irritating enough, trying to get an up and down reading, the dial indicator marred the inner face of the rim. I should have seen that coming, but is didn't mar the horizontal face. Maybe the angle I was able to present the tip to the surface. Any way, I will try Mother's or a buffing wheel.
