New? option;
https://www.ebay.com/itm/1927878205...uid=tW1migcmQPO&widget_ver=artemis&media=COPY
Brake Caliper Piston - Yamaha XS360/400/500/650/750/850/1100 SR500 XJ650 XV920
Reproduction front brake caliper piston for the Honda Gold Wing GL1000 1975-1977 and many Yamaha 360-1100cc models from 1976-1984. Stock calipers have a tendency to become corroded and the piston can seize inside the caliper. If you're rebuilding your front caliper it might be time for a new piston, especially if the original piston is pitted. Ride safe and brake with confidence!
Price:
US $23.95 free shipping, Hayward, California
Replaces Honda Part Number: 45107-371-006
Replaces Piston Only on Yamaha Part Numbers: 1L9-25810-03-00, 3H5-25810-02-00, 1L9-25810-14-00, 3J6-25810-52-00
Specifications:
Material: Nickel plated carbon steel
Diameter: 38mm
Overall Height: 41mm
Height of top section: 8mm
Groove: 4mm
Diameter of top: 35mm
Fits Yamaha:
XS360/C - 1976 - Front
XS400/S - 1978 - Front + Rear (Does not fit XS400SE)
XS400D/E/F - 1977-1979
SR500 - 1978-1981 - Front
XS500C/D - 1976-1977 - Front
XJ650 R Seca - 1982 - Front
XS650 - 1977-1984 - Front + Rear
XS750SE/SF Special - 1977-1979 - Front + Rear- (Double check dimensions - more than 1 size was used)
XS750 Special US - 1977-1979 - Rear- (Double check dimensions - more than 1 size was used)
XS850 - 1980-1981 - Front + Rear- (Double check dimensions - more than 1 size was used)
XV920/RH/RJ - 1981-1982 - Front
XS1100/E-H - 1978-1981 - Front + Rear- (Double check dimensions - more than 1 size was used)
random xs650 parts found at caltric.com free shipping USA
I've used their brake pads work good.
