I've read some of those threads and restrain myself on cold throttle twusts
Yamahaxs650.com I forget the tech description but I considered buying Devcon, screwing around to repair, getting the shit in my hair and on my weiner and decided $24.95 was a fair gamble. I won't look at it again unless the motor blows up, until August, 2023, so only time will tell.which supplier did this come from? it does look a lot stronger.
On this item the perforated sheet metal extends around the entire perimeter behind the screen. I was pleasantly surprised given the guarded reputation these pieces have previously earned.Take a close look at it. That perforated sheet metal backing doesn't extend out around the point that always tears (the point on the right in your 2nd pic). So, this replacement rips just like originals. They reinforced everywhere except the spot that needs it most, lol.
Yes there is a snug fitting "saddle(?)" in the perforated sheet that returns very close to the tube at the perimeter. It seems the support tube is close to the mesh also. Have there been failures right there?No, I don't think so. Take a close look at this area here .....
There is a tube around the mounting bolt hole to support it but the perforated sheet runs behind it usually, unless they've "upgraded" the design.
I believe this is the key. I have yet to tear one. OTH, I have not acquired an engine or bike that didn’t have a torn sump screen.Just take it easy, keep the RPMs at about 4K or below, until the motor warms up a bit and the oil thins
Is this suitable? It says resistor in the literature. LB05FIt looks like you still have the original plug caps. I just replace them with NGKs. They're cheap and very good (basically the standard of the industry).
Yes. The "05" in the part number means it's a 5kΩ resistor cap. Remember, with the stock or Honda coil, you want the resistor caps or plugs... not both...Is this suitable. It says resistor in the literature.
Shit, another thing for me to not remember.... Thanks for the info.Yes. The "05" in the part number means it's a 5kΩ resistor cap. Remember, with the stock or Honda coil, you want the resistor caps or plugs... not both......
