Tales from the annual. Ver. 2025
It's that time of year again. Riding season is about here. A few weeks ago I blew all the dust off her and set the petcock to prime. Voltage was 11.2v, so I wasn't hopeful. Like the good girl she is though, she lit off on the first press of the starter... just like she'd run all day yesterday and had a full charge. Was impressed I was. Anyway, time for the annual inspection.
I've had a few little niggles with the clutch last year, so I decided to see if I can make it better. Don't get me wrong, the clutch works better than most, but there's always room for improvement, especially if you're a born tinkerer, right? The main niggle is the system stiction. Anytime you're feathering the clutch it's got a little "hitch" in it when you try and pull it in slightly. Makes it hard to do stuff like riding off a curb or somesuch.
So, off with the pegs, brake lever and shifter so I could pull both sidecovers. First thing I notice is my homemade stomp shifter has rust spots on it. Then I realized I'd never sent it out for chrome after I made it. That was 3-4yrs ago and all it has is spots. I can live with that. For the cost of chrome these days, I'll just polish it up every annual.
Next up I pulled the covers and pulled the clutch apart. As I suspected, there's some grooves worn into the basket where the plates ride. I don't think that's the entire source of the stiction, but at the least it ain't helpin'.
Took a Sharpie and marked both sides of the basket thingies.... their name escapes me at the moment, but marked 'em to keep track of which ones I filed down. Then gently cleaned 'em up with a fine, single cut file.
That done, I put it all back together. Didn't mic the plates. Visually they looked just fine, so back in they went. I remember a few days ago a forum member put up some pics of the basket holder he made for torqueing the countershaft nut. It was a thing of beauty. Mine is outright caveman tooling in comparison, but it does the job. I give you the ubiquitous modified vise grip basket holder.
Torqued to 50 ft-lbs, bent the tab over and put it all back together.... remembering to align the dot and hole even.
Forgot, while it was apart, I removed the two piece pushrod and installed the single piece aluminum rod I made.
Did a few other odds and ends.. desulfated the battery and topped it off. Still strong after 5+ yrs now. Lubed the clutch cable with a drip of my brew of tungsten disulfide powder and 2 stroke oil, though that may prove redundant. Stay tuned.
This annual is a bit different... or at least it feels that way. I'm not sure what this season holds. I've issues I won't go in to right now. If I'm lucky, I'll get another season's fun out of her. If not, she'll go up on the market so someone else can enjoy her... she's not built to sit in a garage in the summer. Either way, she's due an annual.
And Tink wasn't out there with me like she always was. Dogs make the best company. You talk to them like people and they listen attentively... almost like they understand. She's been my garage sidekick for so long I forgot what it's like out there by myself.
I miss you, Tink.
