Just out of curiosity - Airplane Guys
Nothing like waiting until the last minute to crank the gear down...:D
My guess is that when the Air Data Computer sensed the increase in AOA and impending stall, it set off the gear warning horn... prodding the pilot to place the gear handle down.
The Arrow was like that If AOA and engine RPM showed a landing was imminent, it'd honk the gear horn then deploy the gear on it's own.
Confession; it saved my bacon once. Whew. Balked landing, clean up, divert to a cross runway, forgot to put gear down the second time....
Honk! and bump, gear down on short final. Never-ever forget to do a final GUMPS check when you are sure of a landing.
The saying is there are two types of retract pilots, you can guess how it goes.
A small Private Jet crashed in Florida Learjet went down like a missile
I vaguely remember another one some years ago flying at level altitude but it was not possible to contact it ( not sure what brand )
A fighter jet went up flew alongside and if i Recall correct there was frosted windows and the Fighter Pilot could not establish any contact
I Believe it flew until fuel was used up and went down
Anyone knows more about these planes Ice was one theory now
I think this one may have been the flight that pro golfer Payne Stewart was on (with 5 others). It was a Learjet 35. The theory I think I remember reading was sudden cabin depressurization?
Yes, probably quite correct. Whatever it was, likely ending in hypoxia as the root cause.
An unnoticed loss of pressurization leads to euphoria before death by hypoxia. I don’t really know anything about that particular Jet or remember what the outcome of the investigation.
The NTSB determined it was a loss of cabin pressure. Whether or not it was explosive, rapid or slow was indeterminate.
Me personally, I think it was slow. Slow enough to not pop your ears... so they never noticed. And that brings up the question of why they didn't do a periodic scan of the PAC panel. They're supposed to.
Me personally, I think it was slow. Slow enough to not pop your ears... so they never noticed. And that brings up the question of why they didn't do a periodic check of the PAC panel.
And the plane blasted into the earth at great speed, so I guess it was tough to determine what actually occurred from the shards of the physical evidence.
Good explanation of the "coffin corner" and how ice affects it.
Lear 60's ain't exempt from basic aerodynamics.
Dumb question .. but if at 41000 feet and it stalls is there not time enough for recovery or is the pilot bouncing around or so
Or the full Thrust down .. giving no lift via Supersonic over the wing ? .
Or ice preventing it. If so dangerous
Read an interesting write up from an investigator specifically about the Lear 60 and how the T tail and rear wings made it more susceptible to loss of control when icing occurs and that weather conditions at the time and area were ripe for that to be a possibility
Yes, there is enough time and altitude, provided the stall is all you're dealing with. And even then it's difficult.
In this case a severe T-storm and icing got added to the mix, making stall recovery more difficult.
... and if that storm tore your horizontal stab loose, stall recovery becomes all but impossible.
